Question about Pride Mobility Products Pride Victory 10 - Three Wheel
What causes an 8 beep warning signal
The scooter also stops abruptly when throttling down.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 87 Answers
8 beeps means possible Controller fault.
Posted on Nov 06, 2014
SOURCE:
My scooter won't start when it does it won't go in reverse whenever your going straight it won't slow down and stop you have to coast till it stops Judy Carter.
Judy,
You have a dangerous situation there, The throttle does not sound like it is attached very well to your lever. When you release the lever and the scooter keeps going! This is not safe. The throttle must be in the center of the throttle pots range. Most throttle pots are 5000 ohms. So the center is 2500 ohms or in neutral. The the throttle lever must be checked for cracks in the middle, which release the pressure of the setscrew on the pot shaft. also the return spring may be broken, which would cause a similar situation. Please check these things or get a tech on this before using this scooter again, for your safety and others safety. Scooter Doctor App
I’m happy to assist further over the phone at https://www.6ya.com/expert/bill_bcbb89783b08c489
May 30, 2016 | Health & Beauty
Ctm scooter slows down all by it self and stops but I still got full battery life it's like the breaks are coming one bye them selfs
Raj,
There are a number of causes for this. What is happening is an interruption in the signal going to the controller. One of the first things to check is if the throttle is self centering, the spring maybe broken, or more likely the throttle is sliding on the pot it is attached to. A wire maybe broken in the tiller harness. Loose connections to the motor can do this. Scooter Doctor App
Sep 13, 2015 | Ctm Health & Beauty
I REPLACED THE THROTTLE CONTROL ON MY PRIDE V10 SCOOTER AND RIDING IN GRASS IT STOPS AND BEEP 6 TIMES
6 beeps =
Throttle lever (pot) is not in center position. Return throttle lever
to center position, then turn scooter OFF then ON.
Mar 07, 2015 | Pride Victory 10 3-Wheel
I have a Pride 4 wheel Go Go Elite Traveller Scooter. It generally works fine, but I will frequently get an 8 beep error code and it won't go after a stop. I merely turn the key off and then
BEEP CODE CONDITION SOLUTION
2 Battery voltage is too low to operate Charge the batteries fully until charger and
the scooter. any meters indicate completion.
3 Battery voltage is too high to operate Contact your authorized Pride Provider for
the scooter. assistance.
5 Solenoid brake trip. The manual freewheel Remove the key, then push the manual
lever may be in the freewheel position. freewheel lever to the drive position and
restart the scooter.
6 Throttle trip. The throttle control lever Release the throttle control lever completely,
may have been depressed while inserting then reinsert the key.
the key.
7 Throttle trip. Throttle potentiometer Contact your authorized Pride Provider for
fault or speed potentiometer fault. assistance.
8 The motor is disconnected. Contact your authorized Pride Provider for
assistance.
9 Possible controller trip. You may be Shut down your scooter for a minimum of
attempting to install the battery pack while several minutes to allow the controller to
the key is inserted or the motor controller cool. Or, try reinserting the key into the key
may be in overheat protective mode. switch.
What you may be doing is mis-counting the beeps and it may be 9 beeps or its 8 and you have a bad connection between the motor and the switch? Good luck!
Jan 19, 2015 | Pride Health & Beauty
Scooter shorts out while runing
possible throttle pot failure.
Aug 23, 2014 | Health & Beauty
How do i fix a throttle on a sterling sapphire mobility scooter
The Sterling Sapphire is not sold in the USA so, you may want to verify this information with a local technician however; 7 flashes or beeps is commonly a throttle issue. When the problem starts and you have been driving for awhile, ensure the throttle lever is in the stop position, turn off scooter, wait 10 seconds and turn scooter back on. If that does not clear your problem: There should be two set screws (very small) that you can tighten with an allen wrench on the throttle lever. Make sure those are tight.
If this is a continuous problem, you may need a new throttle potentiometer.
Apr 29, 2014 | Health & Beauty
How to stop a continuing beep on my Cordoba scooter when I turn the key on? The scooter don't move at all.
Hi Mag,
I have this steps that might help you with beeping sound on your Scooter. Hope it helps.
UNIT LIGHTS UP/HORN WORKS BUT UNIT WILL NOT MOVE
Possible Cause:
  • This often occurs when the scooter is in free wheel mode and is not in drive mode. Re-Engage the free wheel lever which is located down near the rear wheels (normally a yellow or red lever).
  • If you hear a beeping noise, the beeping you hear is a fault beep indicating the scooter main control box has detected a problem. Contact your dealer who can diagnose the beep code.
  • Check batteries with load tester - If either battery drops more than 1 volt under a load, the battery(s) are bad. Replace "both" batteries.
I also find these additional steps on how to know beep alarm indicators:
This main control box has a self-diagnostics feature & cannot be tested with a volt meter. When a
problem is present the main control box will diagnose the fault, prohibit the scooter from being driven
and sound an alert beep. Each alert beep indicates a different issue which helps to determining the
problem by narrowing the fault into one of a few main areas of the scooter. Reference this information
below for the alert beep indications.
Very Rapid beep- Batteries are low. Charge & test batteries.
Medium Fast beep- Motor/brake wiring fault. Free wheel lever disengaged.
Solid beep- The charger is plugged into the scooter (some models may vary).
Very Slow beep- The throttle pot was not at center when you turned the unit on. Throttle pot off
center or wiring (yellow & orange wires) fault.
Apr 24, 2014 | Shoprider Health & Beauty
Go Go Scooter travels in reverse, but when going forward it comes to an abrupt stop every few seconds. Everything else appears to work normally. Any ideas?
csr4 Well it could be the throttle pot or the speed control pot My leanings is toward the throttle pot since it works in reverse with the speed pot not being changed but not forward. when you are just changing the position of the throttle to forward thereby changing the pot wiper and getting the error. Contact Pride about the problem at 1-800-800-8586 and ask for Tech support for scooters and explain your problem to them. I hope this helps
Oct 02, 2010 | Pride Go-Go Ultra X 3-Wheel Travel Scooter
Constant beeping, won't run
The beeping on shopriders usually means that the Main Control Box is faulty. It may also be caused by the Throttle Pot being out of neutral. This is a common promlem on this model of scooter as they use a Plastic throttle control lever instead of a metal one. Unfortunately, the plastic one's sometimes slip round slightly causing the above problem. Throttle pots can be very difficult to set to neutral without a multimeter so may be best left to you local dealer.
Jul 01, 2010 | Echo 3 TE SL7 3 New Electric Scooter by...
Pride Mobility Products Pride Victory 10 - Three Wheel Logo
179 people viewed this question
Top Pride Mobility Products Health & Beauty Experts
Rob Hill
Rob Hill
Will
Level 1 Expert
Marvin
Marvin
Are you a Pride Mobility Products Health and Beauty Expert? Answer questions, earn points and help others
