Grease was discarded, cleaned with hot soapy water. Will it put toxic chemicals in cooked food?
SOURCE: melted carousel in microwave / bad smell
For the smell, do a Google search for "smell microwave" or "odor microwave" for many great tips.
If you need a new turntable support, you can order Sharp parts from Tritronics at http://www.wehaveparts.com
It's part # FROLPB017MRK0
SOURCE: Have the new microwave for two months. Working
Sounds like it is overheating due to a failure of the turntable or stirrer or the magnetron. Since it's less than one year old, it would be fully covered under warranty. I'd suggest contacting the manufacturer to get it fixed free.
SOURCE: The Microwave is heating up and appears to
If you can't get the food warm or hot, the problem is usually that the magnetron has gone bad. It's an expensive part to replace compared to the price of a new oven.
SOURCE: This is now the 3rd
if out of warranty you can try a simple "fix" . some microwaves are made with a simple fuse on the inside of casing- should be able to remove cover with 4-6 screws and then locate fuse- DO NOT TOUCH ANYTHING ELSE! If in doubt replace the whole thing.
PS- if dusty inside ,use canned air(for computers or cameras)
Hello - Interior cleaning after convection, mix or broil cooking:
Spatters may occur because of moisture and grease. Wash immediately after use with hot, soapy water. Rinse and polish dry. Harder to remove spatters may occur if oven is not thoroughly cleaned or if there is long time/high temperature cooking. If so, you may wish to purchase an oven cleaner pad with liquid cleaner within it-not a soap filled steel pad-for use on stainlessor porcelain surfaces. Follow manufacturer's directions carefully and be especially cautious not to get any of the liquid cleaner in the perforations on the wall or ceiling or any door surfaces. Rinse thoroughly and polish dry. After cleaning the interior thoroughly, residual grease may be removed from the interior ducts and heater by simply operating the oven on 450 F for 20 minutes without food. Ventilate the room if necessary.
Interior cleaning after microwave cooking:
Cleaning is easy because no heat is generated to the interior surfaces; therefore, there is no baking and setting of spills or spattering. To clean the interior surfaces, wipe with a soft cloth and warm water. DO NOT USE ABRASIVE OR HARSH CLEANERS OR SCOURING PADS. For heavier soil, use baking soda or a mild soap; rinse thoroughly with hot water. NEVER SPRAY OVEN CLEANERS DIRECTLY ONTO ANY PART OF THE CONVECTION MICROWAVE OVEN.
For Complete Defrosting
Turn the temperature control to the
OFF position and unplug the freezer.
Remove all food and place it in
corrugated boxes, insulated bags,
picnic coolers, etc. Use towels and
newspapers for insulation as needed.
With the door/lid open, use pans of
hot water to speed loosening of frost.
Remove large pieces before they melt.
Chest models have a defrost water drain
at the front.
NOTE: Water may drip from the back flange of
the lid cover during defrosting. This is normal.
Ice builds up in the lid insulation when the lid is
open for adding or removing food, and melts
during the defrosting operation.
Sponge excess water from the bottom
of the freezer as it collects to prevent
overflowing.
After defrosting, clean the inside of the
freezer (see Care and Cleaning).
Replace the drain plug inside the
cabinet and the cap on the defrost
drain. Fold over and dry the gasket
on the hinge side of the lid.
Plug in the freezer. Return the
temperature control to its previous
position and return food to the freezer.
Hopefully with this information you can find the drain. If not go to www.ge.com and click on service and support to download your manual. (Model number required)
or contact them here:
800 GE CARES
(800.432.2737).
Thanks for choosing FIXYA,
Kelly
Loosen up gunk and grease splattered inside your microwave by following this simple tip. Fill a pyrex measuring cup or other microwave safe bowl with one cup water and put in microwave on high for three minutes. This should bring the water to a boil. Let it set in microwave for several minutes with the door closed.
Then, wet a sponge or soft rag with a tablespoon of vinegar. If you need a degreaser, add a few drops of dishwashing liquid to it. Wipe microwave clean with the rag or sponge. The microwave will practically clean itself. Now that was easy!
