Took battery out screwed end back on now it wont open
SOURCE: how do i take a battery out of a 1993 buick regal?
look along the sides of the battery toward the bottom it is usually just a clamp that is screwed in place to keep the battery from sliding
SOURCE: Battery compartment in Magellan SporTrak
I used a Dremel Tool with a small drill bit to drill it out without killing the threads. It then popped out. My only problem now is finding a screw that fits the threads....
SOURCE: size 377 battery wont go in - need to unscew something?
I presume that a 377 battery is the same number as what came out. Sometimes there is a small piece of metal that is a strap that helps hold the batter in. Usually, then there is a very small screw that you have to loosen to remove the plate or just move it a bit to get the battery in. Be sure that the battery is not upside down from the way that the original was placed in. Also when putting in a new battery be sure that you don't use metal tweezers to hold the battery as it will short the battery and discharge it. Use your fingers or plastic tweezers.
SOURCE: took apart, pull magnets from sides, now the thing
ECARRERO2004 - Those 'magnets' you removed from the sides of your mixer are the electric motor brushes that provide power to the commutator/armature assembly so your motor runs. Did you remove the brushes to replace them or were you just inspecting them? I'd suggest removing them again and making sure the contacts are facing in the right direction to contact the commutaor. The concave contact face should be resting completely on the comutator. If you've turned it 90 degrees too much, it wont' seat properly and you'll get no 'juice' to the electric motor so it won't start. I hope this helps - Howard, Burke, VA
If this solution has helped you, please rate it. hslincoln
SOURCE: I have a Sony Clie and I want to replace the
there is no other screw, the cover is clipped together, that's why you cannot remove it.
Use a flat screw driver to open it from the sides that is clipped together, you need to apply force in order to open it.
You could still further check for any screw, but I doubt if there is any.
Good luck.
