Question about Makita 2 Bl1830 18v Battery,dc18ra Charger Lxt Fr Drill
Need value of the 1 watt resistor in the 18vdc charger battery holder.
2 Suggested Answers
SOURCE:
puertobori
  • 7733 Answers
SOURCE: I have one Makita battery
Look at eReplacementParts.com and the parts diagrams
Posted on Nov 02, 2010
Resistor value of R704 of Sharp tv model 21v-fk200m
How do i unlock sharp crt tv model 21v-fk200m? i forgot the ...
www.fixya.com/.../t25439922-unlock_sharp_crt_tv_model_21v_fk200...
Feb 17, 2015 - Question about Sharp Standard (CRT) Televisions .... What is the valueof resistor R704 in SHARP TV model 21V-FK200M circuit diagram.
Sharp value 2 watt resistor Standard (CRT) Televisions ...
www.fixya.com > ... > value 2 watt resistor > Standard (CRT) Televisions
value of r707 sharp model #27c241 R707 is 27 ohm 1/2 watt carbon resistor,if you ... What is the value of resistor R704 in SHARP TV model 21V-FK200M circuit ..
Dec 28, 2015 | Sharp Televison & Video
Need a circuit diagram of a dewalt charger DE9108-xe 7.2V-18V one hour charger type 1:Q 96307-12/15 OUTPUT : 2.6A 7.2-18.0V 46.8VA
Can you (carefully!) measure the volts across them with a load (battery) and then the current through them by disconnecting one end, and if the charger is still working OK then they are V/I ohms, choose nearest value. 10k sounds very high, are you sure they aren't 1 ohm or less?
May 21, 2014 | Dewalt 7.2-18.0 Volt One Hour Charger
Resistor for wahl dog clipplers
The value of the resistor is 7.5 ohms, half watt or 1 watt will do the job. Not available from Wahl except as part of the PCB so an electronics store is the place to go. Whenever I find one of them burnt out I include a new set of batteries as part of the repair.
Oct 22, 2013 | Wahl 9590-301 ProSeries Pet Clipper Kit
Is there a way that you can tell if your resistors are blown
Hi
Thanks for using FixYa. By looking at the resistors you can see if they are burned or brown color. Only the resistors with small value blow(getting open) like 1 ohm 1/4 watt or 1 ohm 1/2 watt or 10 ohm 1/2 , 1/4 watt some times the bigger one like 100 ohms, the bigger than 100 ohm just changing the value and make problem.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Jan 22, 2010 | Televison & Video
Amp repair advice
check on the board to see if there is a resistor that looks similar, 90% of amps amps are matched in there design, meaning the left side is usally a carbon copy of the right, so if you look at one side and there is a resistor that looks like it's in the same spot on the other side, good chance thats the same one, read the colors off the one thats not burnt up. resistors come in different wattages,1/8,1/4 1/2 up to 10 watts, each wattage is a different size, most of the ones you see in the amp are 1/4 watt but some are 1/2 and 1/8. some on the output are 2 to 5 watt, but those are generally 10-18 mm in length, they are big ones you cant miss those. so once you get the color code, read the colors, ex red,gree,brown,last line is either silver or gold, that will tell you the resitor value. then google resistor color codes and then you can match the color sequence with the value codes, and that will tell you the value you need in ohms but then you have to get the size 1/4 watt resistors are generally about 6 mm in legnth, im measuring the actual part of the resistor not including the metal leads, just the body, so if its larger its probally a 1/2 watt if smaller its an 1/8 watt, 1/8 watt are about 4 mm. now go buy the resistor, but you might find it that tough, if its a common value radio shack might have it, but resistors are so cheap, pennies for a handful, good luck on your search.
Jun 30, 2009 | Sony Car Audio & Video
It transmits but doesn't receive.
Check resistor R31. In some radio's when 1/6th watt resistors were used to save money, sometimes the smaller resistor heats up and looses its resistance value. Try replacing it with the same value, but higher wattage. 1/4 watt, 47 Kohms resistor. Its color code is yellow, violet, orange, gold.
If this doesn't work it may be something else that needs to be traced down.
Jun 21, 2009 | Cobra 29 LTD CB Radio
Excessive brightness with retrace lines
Here are the values:
RY04 >>>> 68 ohms >>>> 1 Watt
RY04A >>> 47 ohms >>>> 0.5 watt
RY02A >>> 330 Ohms >>> 0.25 Watt.
All resistors should be 5% tolerance.
Apr 17, 2008 | Apex Digital GT2715DV 27 in. TV/DVD Combo
Part numbers
wiil get back to you.
Mar 16, 2008 | RCA 32F531T 32" TV
Makita 2 Bl1830 18v Battery,dc18ra Charger Lxt Fr Drill Logo
95 people viewed this question
Top Makita Drills Experts
John Trevino
Marvin
Marvin
Spud Howell
Are you a Makita Drill Expert? Answer questions, earn points and help others
