SOURCE: tRUCK IS RUNNING HOT AND WATER IS LEAKING
There are many locations water can leak from. Worst case is the head gasket its blown and the water is leaking into the combustion chamber or the block. Best case check hoses and radiator. Also make sure no air is in the system. Check freeze plugs as they corrode out.
SOURCE: Radiator replaced on 2000 Volkswagen 2.0 engine
The plastic jug (Coolant Recovery Reservoir) could have a hairline crack in it or check the small hose that goes from the Radiator neck (Opening) to the Reservior.
The Thermostat would not be an issue in this case.
SOURCE: Car started smoking like hot steam from water jug
You most likely have a broken head gasket and it's leaking coolant water into your combustion chamber, therefor the white smoke at the tail pipe and loss of coolant. This is serious as it could damage your engine if not taken care or immediately.
