I have a problem with the auto time function on our u1721 built in oven. When we try and set the oven auto on timer, the main oven fan and element stay on, the oven does not go into oven cooling fan only mode.
SOURCE: Changing an element on the main oven - Neff U1721 Double oven
You should not need to remove fan to access the element fixing scew(s).
You may need what is called a torx screwdriver, if the screws are conventional screws, but some times a small screwdriver will undo them if they are not too tight.
let me know if you require any more assistance.
Plz rate my solution.
Thanks.
SOURCE: unable to remove the fan blade on the neff u1721 oven (too tight)
The nut is a left hand thread, so unscrew it clockwise to release it, hold fan blade as you are doing this. Tighten anti- clockwise.
Thanks.
SOURCE: My Neff U1721 main oven does not heat up at all on
CIRCOTHERM ELEMENT ROUND ONE BEHIND MAIN OVEN BACK PANEL D.I.Y JOB EASY TO REPLACE AND CHEAP
