Washing Machines Logo
B
BRENDA BROWN Posted on Oct 28, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
WHIRLPOOL DUET WASHER MODEL #WFW9600TW01 F-35 & F-28 ERROR
SUDS ERROR WILL POP UP THEN GET F-35 MESSAGE & SOMETIMES F-28
jeff hartman
Level 2:
Scholar:
  • Expert 79 Answers
  • Posted on Jul 10, 2015
jeff hartman
Expert
Level 2:
Scholar:
Answers
79
Questions
0
Helped
87391
Points
166
Outside the normal analog pressure sensor (APS) / hose checks...
Another cause for the F35 and SUD error could be your CCU (control unit). There are components that seem to fail over time and cause the F35 and SUD errors. You can replace those components yourself now...
See f35error.com for more information.
I hope this helps and let me know if you need anything else!
Jeff Ditto
Level 1:
  • Contributor 30 Answers
  • Posted on Oct 28, 2014
Jeff Ditto
Contributor
Level 1:
Answers
30
Questions
Helped
12833
Points
86
The F35 indicates a water level pressure sensor failure. A loose wire harness connection could be causing this problem if there is no water or suds in the tub. I recommend unplugging the washer and removing the top panel. Screws at the very back of the top panel secure it to the washer frame. Remove the screws and then pull the top panel slightly back and then up and off of the washer. The analog water level pressure sensor is shown in the first image below. The second image shows a clear picture of this component. Check the wire harness connection on this sensor. If you find a loose connection, secure the wire harness properly on the component then reassemble and test the washer. If you continue to get the F35 code, then the pressure switch will need to be replaced. I hope this helps.
also for the F-28 issue
http://fixitnow.com/wp/2011/06/30/how-to-troubleshoot-an-f28-error-code-in-a-whirlpool-duet-sport-washer/
5 Related Answers
Anonymous
  • 107 Answers
  • Posted on Mar 20, 2009
SOURCE: My Whirlpool duet washer is not draining. I am
If you hear the pump running and not draining, then take the toe panel off. Should be 3 1/4" screws on bottom. Remove the "coin catch". It looks like a BIG screw and it's white. Turn counterclockwise. There may be a sock, change ect...clogging it up. Dump it out and run machine. Have towel or bucket ready when removing coin catch.
TheMobilian
Dan Webster
  • 8221 Answers
  • Posted on May 02, 2010
SOURCE: Suds and F35 keep shuting down my laundry day:(
Remove the service panel and see if the filter has something in it77cb04b.jpg2402fad.jpgf032166.jpg
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Anonymous
  • Posted on Jan 16, 2011
SOURCE: Whirlpool Duet Washer-error code "sud"
Just take off the bottom kickplate (3 screws on the bottom). You'll see the pump front and center. Twist the front face of the pum slowly to the left. All the trapped water will flow right out towards you. There could be a sock or some other debris there. Unclog, screw that faceplate back in and start it up.
Anonymous
  • 1940 Answers
  • Posted on Feb 22, 2011
SOURCE: I have a whirlpool duet
  1. First, attempt to unplug the washer for at LEAST 30 minutes to reset the Central Control Unit (CCU). Sometimes this is all that is required to correct momentary glitches with the unit. If the error code returns, proceed to step 2.
  2. Check the drain hose to make sure it is not kinked or clogged.
  3. Check the pump strainer. There are three screws at the very bottom of washer. You will need and extension and a star tip. I used a 9/32 socket to remove them. The front cover slides right off. Facing you is the pump strainer. Big white piece of plastic right in the middle. Turn the large white knob counter-clockwise to remove it and clean. It is the only thing you can unscrew by hand. Open it and clean anything you find out.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Anonymous
  • Posted on May 05, 2011
SOURCE: Sud error then f35 error on Whirlpool duet washer
What hose?
1helpful
What does error F35 mean?
It helps to have FULL make and model in such questions, but here are a few ideas
The F35 error code indicates an analog pressure sensor error. The analog pressure sensor is the component that detects water level in the washer tub. This error can usually be cleared but it will occur again if the main control board still detects a problem with the signal from the analog pressure sensor.
Jun 4, 2011
F35 error code appears during cycle - iFixit
https://www.ifixit.com > Answers > View > F35+error+co...
About
Whirlpool duet washer f35 error code
https://all-errors.com > whirlpool-duet-washer-f35-error
The F35 error code in the Whirlpool washer indicates some problems with the water level pressure switch. This sensor is responsible for measuring the amount ...
Troubleshooting the F35 Sud Error Code in the Whirlpool Duet ...
https://www.youtube.com > watch
PREVIEW
12:49 Troubleshooting the F35 Sud Error Code in the Whirlpool Duet Steam Washer · For more tech advice on ...
YouTube · SamuraiRepairman · Oct 5, 2013
WHAT MEANS ERROR CODE FOR MY DRYER MACHINE F11?
if its a Kenmore model then this message says that the button control board has lost sight of the main control board , but its been my experience that this maybe able to be reset and it may never come back or it will not reset and the control board will need replaced (50/50)
cycling power may reset this
Jan 30, 2016 • Dryers
My Whirlpool Duet Sport washer is giving a F-28 error message. What is wrong?
If you're getting an F22 error, you will want to check anything to do with the door latch switch.
2helpful
3answers
Whirlpool Duet -Sud displays and washer stops
I;ve had the same problem (SUD on first fill) and found this most helpful for my WFW9600TW01 Duet washer
http://www.tellingmachine.com/post/Fixing-Sud-and-F35-errors-on-my-Whirlpool-WFW9600TW01-Washer.aspx
I duplicated his actions and it cleared up my SUD/F35 error. I think running the diagnostic test multiple times flushes the sensors/sensing lines to eliminate the problem.
2helpful
I am getting an F20 error message or SUD. I have
http://www.wikihow.com/Fix-a-Whirlpool-Duet-Washer-F-20-Problem
1helpful
2answers
Our Whirpool duet washer will not spin, gives us the SUDS and F02 message and now the door is locked.....suggestionss?
k now the washer beleives that it is full of water.
pour about 3/4 cup of veg oil in the dispenser. and start the unit.. this will get rid of the suds error.
F02 means long fill.. and the water level has not satisfied the computer for 40 secs. check water connections. making sure they are fully open.
to open the door if it does not unlock, in the dispenser there should be an ODD colored line, five that a tug and the door will pop open
Top Washing Machines Experts
john h
