If PC is not going further Dell logo screen then most of the time its a hardware issue. You can try only to steps to fix this issue easily.
1.Ran a diagnostic of dell by Cd
insert your dell drivers and utilities disk into your drive>>turn off the comp>>restart the comp by pressing
F12 key>>you will boot menu now>>choose the option boot to utility partition>>hit enter>now it will show you 3 test> choose
Express test and hit enter>>now it will start checking your hardware component of your computer
2.If hardware diagnostic pass then you can try dell factory rectory restore.
if you have xp they try this:-
1.Turn off the computer>>restart the pc by pressing
alt+f11 again and again>>now you will get the dell factory restore wizard and follow the on screen instruction. sometime it does not show you the dell factory Restore screen in case if it is damage or corrupted.
hat screen if
If you are using Vista or window 7 then follow this:-
- Restart the computer. To do this, click Start, click the arrow next to the Lock button, and then click Restart.
- As the computer restarts, press the F8 key until the Advanced Boot Options menu appears on the screen.
- Press the (Down Arrow) to select Repair Your Computer on the Advanced Boot Options menu, and then press Enter.
- Specify the language settings that you want, and then click Next.
- Log in as a user who has administrative credentials, and then click OK.
- Now you will get Recovery Tool so here Choose the last option dell emergency backup/factory restore
7.Hit enter and next and next and enter your personal information like country, user name, language etc....and finally you will get you desktop welcome screen.
cheers!
Let me know was this helpful.
