Dell laptop wont charge battery.
I have a DELL Vostro V13 laptop. I have replaced the battery and the charger. http://www.batteriemonde.com/dell-vostro-v13-series.html ,While the laptop will run on AC power it will not charge the battery. It says plugged in not charging. If I restart the laptop I get an error screen that says the charger is not recognized. Is there a solution to this? I know there is an identification pin in the plug end of the charger and it is still there. Any suggest is welcome.Thanks in advance.
    New Friend:
  • 42 Answers
The Laptop charger or the charging point itself is bad or damaged. You'll need to try different charger to take your laptop to any nearest computer repair shop to have charging point repaired or replaced.
Posted on Oct 28, 2014
SOURCE:
No light indicator charging battery adapter
If the computer starts with the power charger plugged in, then replace the battery.
good luck
Sep 20, 2013 | Dell Vostro 1014 Notebook
Vostro v13 freeze
Usually while installing programs, other programs are installed in the process, so try uninstalling some of them that you ate not using them. Furthermore try to find a driver for your graphics card and install it.
Jan 17, 2013 | Dell Vostro V13 Laptop Computer (Intel...
Laptop dell 1015 not charging showing wattage problems
sounds as if battery needs replaced or perhaps the charger...its one or the other
Jun 07, 2012 | Dell Vostro 1015 Laptop Computer (Intel...
I have a Dell Vostro a860. I have a new dell power adapter, a new battery, and have just had the power jack replaced. I still get a message the states that I'm connected but not charging. Any...
Probably the power charging circuit on the motherboard.
The question is, does the battery actually charge, no matter what the screen says? If it's a Dell charger, a Dell battery, then it should work. Some 3rd party batteries cause this message, but in actuality, the batteries seem to charge for the most part.
Jul 02, 2011 | Dell Vostro A860 Notebook
We tried all part replacements for dell vostro V13. but still the problem exists " No operating system found" what will be the cause? please help
When you receive the error, "No Operating System found". There could be one of two things wrong.
Either your hard drive with Windows properly installed is bad,
Or, you haven't installed Windows or the Windows installation is corrupt.
All you have to do is reinstall Windows using the discs provided to you by Dell and you'll be golden.
Apr 30, 2011 | Dell Vostro V13 Laptop Computer (Intel...
The battery in my dell vostro 1500 wont charge and i have already tried a new battery twice. The laptop powers up with the AC adapter but when I check the power meter it says the battery is at 1% with an X...
Sounds like there is a disconnect between the power in and the battery, probably a broken solder joint or a fuse. Unless you are a tech, send it in for repair.
Sep 13, 2009 | Dell Vostro 1500 Notebook
I have dell vostro 1400 laptop.when my latop charger is plugged in laptop is charged but as suddenly when i unplugged charger laptop is shutdown no battry is charged what is the problem?
You have either a faulty/worn out battery or a faulty charging circuit.
Recharageable battery have a finite number of charge and discharge cycles and over the years the battery life gets shorter and shorter until it is worn out and won't charge any more.
If the battery is more than 2 years old then the battery is most likely worn out and needs to be replaced.
Jul 18, 2009 | Dell Vostro 1400 Notebook
Dell Laptop Charger, wont charge bat. but keeps computer running.
Hi there.
In some cases batteries tend to not charge up because one of the cells are damaged or drained to the point that they will not charge at all.
In other cases it can be the power board on the laptop motherboard itself which can have gone faulty, the only way to tell is to obtain another battery (preferably new) and see if it will charge the new one, if it does then you know that the battery is faulty, if it doesn't then you will have to take the laptop into a shop to be looked at.
This is the only way you are going to be able to work out which one of the two is the cause.
Good luck and thanks for using FixYa!!
May 07, 2009 | Dell Vostro 1400 Notebook
Computers & Internet Logo
101 people viewed this question
Ekse
Alun Cox
