Is it ice or frost? Frost would be a defrost problem, but ice is caused by a plugged or frozen drain. Not a board or defrost heater.
Remove evaporator cover in freezer. (Back wall of freezer.) At bottom of evaporator is a trough that catches water that drips when in defrost. There is a hole that is probably plugged with ice. You may need to turn off refrigerator, unplug, open doors and allow it to defrost. Make take 24 to 48 hours. Then check that you can poor hot water into trough under evap and see it drain thru the hole in trough. If it does it again you'll need to have someone install a drain probe a check the drain outlet for restrictions.
SOURCE: Amana BX22A2W - freezer works, fridge not cooling
Check the damper in the top back of the fresh food section. make sure that it is open and air is coming through it.
SOURCE: Evaporator fan stops working due to ice buildup around fan.
you need a drain tube heater.it is like a chain fence tie made from alluminum,you can actually use the fence ties,wrap one side around defrost heater and stick the other side in drain.that will prevent it from happening again
Hi: I've dealt with Kenmore for 30 years. Unfortunately the new model numbers don't reveal the age. I must assume it's a newer model. I'm not disputing what you said about it running all the time, but please read on. Oddly enough the new energy efficient referigators run 70 to 80% of the time. They use a smaller compressor without the big amperage start-up. The best I can describe them is that they freewheel alot. The 106......of your model number means it was built by Whirlpool. A very quite and energy efficent refrigerator. If your power bill is high get a meter from your power company, most have them. Just to double check the power consumption. Good luck Jeff
SOURCE: freezer is working but refrigerator does not cool
JCD2292KTB with frost build up in freezer.
Based on your complaint, it soumds like you have a malfunction in the defrost system.
Listed below are some tips provided by, www.repairclinic.com, which can assist you in diagnosing your problem.
This link will describe how a refrigerator works.
http://www.repairclinic.com/0088_4_3.asp
Here is some diagnostic help!
Cooling is poor
For an overall understanding of how refrigerators should work, read about refrigerators in the How Things Work section of our website. A refrigerator or freezer that is cooling, but cooling poorly, may have a problem in one of several areas:
Evaporator coils
Condenser
Poor cooling is often the result of a heavy frost build-up on the evaporator coils or a condenser that is clogged with dust, lint, and dirt.
Evaporator coils
Poor cooling is often the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer. Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gaskets.
The refrigerator is supposed to self-defrost approximately four times in every 24 hour period. If one of the components in the self-defrosting system fails, the refrigerator continues to try to cool. Eventually, though, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There may still be a small amount of cooling because the coils are icy, but with no air flow over the coils, cooling in the refrigerator compartment is quite limited.
Here's an inexpensive, though inconvenient, way to determine if the problem is with the self-defrosting system. Remove all of the perishable food from the refrigerator and freezer, turn the thermostat in the refrigerator to Off, and leave the doors open for 24 to 48 hours. (Be sure to have several towels ready in case the melting frost and ice causes the drip pan to overflow). This allows the refrigerator to defrost "manually." When the frost and ice build-up has completely melted away, turn the thermostat back to a normal setting. If the refrigerator then cools properly, it indicates a problem with one of three components in the self-defrosting system:
If it still does not cool properly, there may be a problem with the refrigerant level or the compressor. You may need to consult with a qualified appliance repair technician to further diagnose the problem
Condenser
Self-defrosting refrigerators all have a set of coils and a cooling fan, usually under the refrigerator, that need to be cleaned regularly. If these coils get coated with dust, dirt or lint, the refrigerator may not cool properly. The coils may appear to be a thin, black, wide radiator-like device behind the lower kick-panel. To clean them, disconnect the refrigerator from the power source, use a refrigerator condenser brush (see the Appliance Accessories section) and your vacuum cleaner to clean the coils of any lint, pet hair, etc. You may not be able to get to all of the condenser from the front, it may be necessary to clean the remainder of the condenser from the rear of the refrigerator.
