Tried many install and uninstall program options and from internet tools, nothing works.
It seems that you computer has been infected by Search.rockettab.com redirect virus. You can try running a powerful malware removal tool to get rid of this threat. Try this tool: http://guides.uufix.com/Spyhunter_Download.php
Hi ,
Your pc is virus infected . Here is how to get rid of this malware :
http://malwaretips.com/blogs/rockettab-virus-removal/
Regards .
The right installation location for a standard Windows 7 should have been :
C:\Program Files (x86)\RocketTab
Perhaps this explain why you receive an error message ?
Check startup program and remove the program from the startup. Go to Start-->Run --> then type msconfig.exe. On the startup tab find RocketTab and disable it.
Go to C:\windows\system32\tasks and delete all files containing the word 'Rocket' except RTKCPL(Legitimate Windows file). Once you are done with this, try restarting your computer.
Alternatively, you can also type 'msconfig' using the run dialog box and disable all the related startup items using Startup Tab.
Good luck though!!
Push your Windows key + R and then type the following without the quotes "msconfig"
Choose the startup tab and look for that entry, uncheck it. All done! Be careful of what you turn off here and it could cause things not to work properly and even stop Windows from booting.
Installation or uninstallation of an application or game fails and gives the following error code:
This issue is due to a previous installation not finishing properly
Solution 1. Rename the Installshield folder
Make sure you've enabled Show hidden files and folders.
Find and rename the Installshield folder:
Windows 32-bit: C:\Program Files\Common Files\Installshield
Windows 64-bit: C:\Program Files (x86)\Common Files\Installshield
If there is an Installshield file in the Common Files folder, rename that one also (e.g. to Installshield_OLD).
Solution 2. Remove all traces of previous uninstall
If renaming the Installshield folder had no effect, find and delete any traces of uninstalled applications.
Applications that can assist you are: Revo Uninstaller, Windows Installer Cleanup Utility , CCleaner.
Alternatively, do a manual clean-up:
Close all running programs. Then clear the Temp folder (found via input of %temp% in Start > Search or Start > Run).
Use the Windows registry editor to delete registry entries related to the program.
Restart the computer.
hope this helps
