Washing Machines Logo
j
joel Posted on Oct 27, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Avanti portable washer w798ss does not spin
The washer doesn't spin and when I go to the spin cycle this is what happens in the video. I don't know what part to replace
Michael Carroll
Level 3:
Master:
  • Master 742 Answers
  • Posted on Nov 03, 2014
Michael Carroll
Master
Level 3:
Master:
Answers
742
Questions
Helped
171270
Points
1973
Spin clutch is bad, costly repair
Avanti mini washer how do I put it on SPIN CYCLE only???
It would be useful to have the model number, but here are some manuals. Some machine have no option for JUST a spin, you have to choose Rinse and Spin.
https://www.google.com/search?q=Avanti+mini+washer+how+do+I+put+it+on+SPIN+CYCLE+only
Avanti TLW16W Instruction Manual (Page 16 of 32)
ManualsLib https://www.manualslib.com > ... > Instruction manual
x Press down the power button. x Press the cycle button to select the SPIN function until only SPIN indicator is ON. ... the entire course. ... NOTE: All automatic ...
instruction manual - cloudfront.net
cloudfront.net https://dzrf1tezfwb3j.cloudfront.net > uploads PDF Close the lid, or the washing machine will buzz during wash and spin cycle. In the event the clothing loaded becomes unbalanced, the safety switch will be ...
56 pages
Avanti RV Appliances Instruction Manual
CARiD https://images.carid.com > avanti > items > pdf PDF 8. Close the lid. Otherwise the washer will not wash or spin, and alarm will sound. PRESS THE POWER BUTTON.
19 pages
Avanti W798ss does not spin when in spin cycle. Not sure what part to replace. Which part in the Schematic view correlates to the problem im having. thanks
Interesting Lets try camming from your mobile device to see the washer! I like the idea. would be better than sending out a tech to look right! So, how do we do this and maintain annaminity! I am not scared heck! I have no reason to lie! so lets do this! Do you know how to add a video is cool Looks like how you add the video you click add video, look down below this panel.. Use your smart phone to download or copy the link.Nice, you download your video from you smartphone to your youtube channel! Sounds simple enough, send to luckysafehaven on youtube. I can look at it! Yes I can help you identify isolate the problem! What is the cost to replace this part can you do it your self? There are plenty service companies with the experience! I will take time to investigate more upon request!
1helpful
Washer not fully drained before spin cycle then get error message E-5
somethink is blocking the pump , u need to take cover of see what it is?i say its money?
Hi! I purchesed washer mashine Avanti W798SS a few month ago and I have a problem with that- It fill the water and after that in washer regimen it doesnt operate- there is no moving- it shows error sign. I...
If it's still under warranty. Go to the store where you bough from
and ask them about. They'll ask an authorize from the factory and the will find some one to fix for you.
Good luck
Mai
Hi, I have a portable Avanti washer that is
My washer is not turning or spinning could someone please help me
My washing machine turns on but wont rinse my clothes
If your washer doesn't agitate, check these:
Lid switch
Motor coupler
Belts
Clutch
Drive motor
Drive pulleys
Transmission
Agitator
Lid switch If the lid switch is defective, the washing machine may not agitate or function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Motor coupler Many washers produced by Whirlpool® use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. If this happens, you need to completely replace it.
Belts Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
Clutch If your washer was made by GE®, it may use a clutch for agitating the clothes. As the clutch wears out, it may prevent the washer from agitating well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
Drive motor Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
Drive pulleys The motor or transmission drive pulley may be worn and unable to turn the drive belt. If so, replace the pulley.
Transmission The transmission could have either of these problems:
  • Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may not agitate properly or at all.
  • The transmission may have a worn or broken gear, or some other internal problem.
If you suspect a transmission problem, you may have to call a qualified appliance repair technician to repair it.
Agitator The inside of the agitator--where the transmission shaft attaches--can become worn, and strip out the spline that allows the agitator to properly grip the shaft. Then the transmission shaft rotates back and forth as it should, but the agitator doesn't move properly. If this happens, you may need to replace the agitator and/or the transmission spline.
It's noisy Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
Avanti w798ss doest start
Close the lid! There's a sensor on the back hinge of the lid. Make sure its working. You should hear a small click when you close the lid.
Top Washing Machines Experts
john h
