Dell OptiPlex GX620 PC Desktop Logo
Neil Trevor Posted on Oct 27, 2014
I have a dell opticplex gx620. It was working perfectly until the windows crashed. I have been trying to reload windows xp but once i press f8 to accept it will show blue screen.
I have a dell opticplex gx620. It was working perfectly until the windows crashed. I have been trying to reload windows xp but once i press f8 to accept it will show blue screen. I have reloaded the hard drive on another machine but once it gets to the windows logo page it will restarted
Charles Lockhart
Level 1:
Problem Solver:
  • Contributor 19 Answers
  • Posted on Oct 27, 2014
 Charles Lockhart
Contributor
Level 1:
Problem Solver:
Answers
19
Questions
0
Helped
5536
Points
53
You need an actual Dell windows disk to reload to a new hard drive as it will flash the associated drivers and boot sequence to the RAM. Nothing else works with DELL!
5 Related Answers
Anonymous
  • 101 Answers
  • Posted on Jan 05, 2008
SOURCE: reload windows
Hi Dragon,
Try pressing the Ctrl and the F11 key at the same time, right after you boot the PC. You might have to try this a few time, because the time slot of this option is fairly narrow. Should give you the restore partition. Then just follow the prompts. Good Luck!
Anonymous
  • 458 Answers
  • Posted on Jun 04, 2008
SOURCE: reloading windows xp
Replacement Drive? If you are talking about a Hard Drive the answer is: You can buy any hard drive as long as it is the same type from any computer store. Take your Hard Drive to the store and tell the sales person that you want another hard drive like that one. You can get another Brand or a bigger size if you want to. Your best bet is to completely reload that hard drive and wipe everything off of it and start all over. You can still buy another Hard Drive (Internal or External) to keep your files backed up. That hard drive could have also went bad.
I am going to give you a lot of things that you can do. Like I said this is a lot of information so you might want to print it out and also copy it to a disk for the future. These things will explain how to check your Hard Drive and also tell you how to keep your system running smooth.
I can't fix this for you, but if I helped you get it fixed, please rate it as a fixya not a helpful rating. These ratings let me be allowed to help you and others in the future.
Turn the system restore off. System restore keeps everything in restore. Meaning......... If you have spyware or a virus, it will stay in your system. Run Spybot S&D (This program is free and is better than using msconfig as long as you go through the settings and change everything to the highest settings.) Then do the same with Adaware 2008 (sounds stupid to use 2 things for spyware, but one catches what the other one does not.). I have links on my website (tandnfamilyelectronics-online.com). These links go directly to the download so you will not get the run around. You would do good to try a program called Window Washer (http://www.download.com/Free-Internet-Window-Washer/3000-2144_4-10436825.html?cdlPid=10731707). This is a great program that completely cleans anything in your computer that you do not need. It will not clean out anything that you have to have. I have used this for years to clean out my customers computers and have cleaned as much as 3 gigs of trash out. If you contact me I will give you some tools that I have for free that will do a great job on your computer. I have them ready to download and I will give you the link. ([email protected])
Send me the complete specs of your system and I can help you more. I hope that this helps you. There is no reason the really buy a program for spyware when there are free things to use that work great. Free AVG is a great Antivirus and yes it is also free. It will check your e-mail coming and going. It will also let your friends now that the E-mail does not have a virus. It also has a spyware program that is free. This day and time with all of the spyware out on the net you can never have too many programs for spyware. I would not run all of them at the same time though. Make sure that you do not use your computer during any scan. Defrag is also something to do after you do everything else. Some people will tell you that should not reload your computer. If nothing seems to work then sometimes that is the only good way to get it repaired right. Most of the programs that come pre-installed on a store bought computer is useless and most are even trail software that causes problems when they expire. Let me know if this helps at all. Please rate me if it helps.
HARD DRIVE PROBLEM
This sounds like a bad hard drive. What make of hard drive is in it?
Figure out what brand hard drive it is first. Then go to the website of the manufacturer.
While you are on the site look for software for hard drive repair. It could be listed in many ways. Download the windows version if you have another computer to test this in. If you do not have another computer to test this in you will have to use the Dos version. The instructions will come with the siftware.
Then you will go through these steps.
Do you have another computer that you can use to check the hard drive? If you have another computer or access to another computer you can download a hard drive utility that can diagnose and possible repair the hard drive. Is it a SATA hard drive? If it is a SATA hard drive you can plug it directly into another computer that has a SATA cable. If it is not SATA you will need to buy a converter so that you can hook it up to the other computer. This will be an external slim hard drive enclosure. A desktop hard drive can be put in another desktop and used as a slave drive. Just make sure that you look at the back of the Hard Drive and make put the jumper on the slave pins. Then you can run the test through the other computer to test the Hard Drive. The test will let you know if the Hard Drive is bad or not. If you can see your files on the drive you might want to back them up before you start the test. If it comes back as good go to the next step.
FIX BOOT
You can boot it up with the recovery CD and run through it as if you were doing a setup and then when the second repaircomes up..... hit repair. This should repair any problem with the operating system. If you want to try the simple way... use the first repair that comes up. When the screen comes up with a blinking curser hit the number 1 then Enter........ When it ask you for a password hit enter. There should not be a password unless someone has put one in it. If there is a password it should be your master password.
Then type fixmbr and hit enter. This will fix your master boot record. If that does not work use the second repair. Sounds complicated but it is not.
CDROM PROBLEMS / Hard Drive Problems
Check your IDE cable inside that plugs into it. This will be the wide cable. Does it light up? Your power supply could be going bad. Unplug them one at a time and see if they work. Look at the jumpers and make sure the last one on the cable is on Master and the other one is slave. Sounds like a bad cable or connection if you swap the cable and see if it works.
Mykel_N
Mike Neath
  • 315 Answers
  • Posted on Jan 25, 2009
SOURCE: can't reload Windows XP Pro on Dell 4500
Have a look at these for more info:
http://www.pcuser.com.au/pcuser/hs2.nsf/web/3D2F91493F7B80D5CA256EA80038C9A7
http://www.codeproject.com/KB/work/installwindowsxp.aspx
http://lifehacker.com/software/windows/geek-to-live-how-to-format-your-hard-drive-and-install-windows-xp-from-scratch-157578.php
I hope that helps.
Anonymous
  • 258 Answers
SOURCE: can't reload XP
Depending on the age of your PC it may have Dell automatic recovery
During startup at the Dell Screen hold down the CTRL key and tap F11 twice
It may display the Dell Recovery from which you can set your computer back to factory settings
Please note all your files will be deleted
Anonymous
  • 61 Answers
  • Posted on Mar 30, 2009
SOURCE: blue screen when i install xp
Thats the blue dump error .so format the drives and reinstall the os
Windows xp sp3 will not start just frezzes . canot get into safemode
Your first step should be to put the XP CD into your computer and try to perform tasks from the Recovery Console. I'd suggest a "chkdsk /r" and maybe even a "fixboot". If those don't allow you to get back into windows then try to do a "repair install" of Windows. This is just a temporary measure, to recover any files you don't want to loose. A repair install is a very unstable reinstall of windows, basically installing windows ontop of your current windows install. It can result in the computer crashing again, so should not be relied upon. Once you have all your data backed up I would suggest a complete reformat of the computer.
My sansui pc/tv monitor isn't working properly when I connect it to my desktop.
Windows is likely crashing while loading recently upgraded device drivers. The most common culprits for this scenario are video drivers.
The next time you boot, as soon as you see the Dell splash screen, start tapping the F8-key about once every second until you see a white on black menu. If you see the Windows logo, you missed it (try again, this time start tapping the F8-key a little before the Dell splash screen).
This menu will allow you to boot Windows in "Safe Mode", which will bypass any non-essential drivers and applications that could be causing the crashing. Select "Safe Mode with networking".
Assuming the computer booted fine in Safe Mode, you will be able to remove the troublesome drivers. You will see an informational message about Safe Mode, which you may close at any time. Right-click "My Computer" and select "Manage". Wait a moment for the Computer Management window to appear. Then, click on "Device Manager". If Windows was able to identify the faulty driver, it will appear in the list with a bright-yellow triangle. If this is the case, right-click and "uninstall" it. If it did not show up, first click the tiny white triangle next to "Display Adapters" and "Monitors" to open those categories. Then, right-click and "uninstall" everything listed within the two categories. Your computer will probably boot normally after doing this. But, try and find the proper driver for you video adapter before rebooting if possible. I recommend also re-installing the chipset drivers which may be related to the problem.
To attain drivers for your specific Dimension B110, visit the following link and enter the service tag code on the back or side of your machine: Dell Drivers
Dell XPS Studio PC Desktop
Remove all USB attached devices like drives.
You may need to roll back system with System Restore. Under Safe Mode (press F8 during boot and choose Safe Mode).
Win 7 - Start > Start > Search type System Restore.
XP - Is Start > All Programs > Accessories > System Restore. Now choose a date prior to problem. You may have to try a few dates.
Uninstall last program(s) that was installed, again in safe mode.
To eliminate possible bad RAM. Unplug PC, open case, and remove all RAM. Test one DIMM at time, one slot at a time.
Re-install Windows. Clean install works best, but all data will be lost.
Lastly you may have other hardware problems. If it does another blue screen after reloading windows, especially with a clean install.
Power meter key (fn + f8) doesn't work
you lost the driver for that. key, its HP only key.
HP driver,
BUT NO PC stated, by it has full product name and number.
are you the only one on earth running XP>
MS shut down the driver server service 3 years ago.
here ask at HP, real, not fixya we are not HP.
https://h30434.www3.hp.com/
warning, they will ask you to tell them what you own.
name and model, etc. or all bets off, XP is now LEGACY,
I have installed windows 7 ultimate 32 bit in my dell vostro 1015 ,now i want to change my windows so is it possible that i install windows xp in my dell vostro 1015
Yes it is! You're going to need a Windows XP install CD and a serial key. Once you have those, we can start. Put the Windows XP Install CD in your computer, and reboot. Press F8 when the computer comes up to get into the boot menu. If F8 doesn't work, try F2, ESC and Enter. Select the CD/DVD drive from the list, and when you see the prompt to push any key, push any key. The files will load, then you'll see a Welcome to Windows screen - press enter. The next screen will show your hard drive. You're going to have to format it here, so you will lose all your files. Backup any files you need before you do this. Highlight the biggest sized partition, and press D, then follow the prompts. Now press C over the unallocated space, and choose quick format. Then press enter. Agree to the EULA by pressing F8 Windows will now begin installing. Follow the onscreen instructions and you'll be just fine. Alex
Cant activate windows xp home edition
Hi
Try and see what the BSOD says , when it suddenly reboots. Press F8 until it gives you a menu , go to advanced options or something similar highlight don't reboot or restart automatically.
Can you start your PC in safe mode. Try a crack although I wouldn't recommend it.
5helpful
4answers
Error: Cannot Display This Video Mode
You may have to boot into safe mode and reset the video settings to a safe setting like 1024x768.
  1. To get into safe mode, continuously press F8 while the computer is booting up.
  2. Eventually you will get a Windows XP Boot Menu.
  3. Choose the option for Safe Mode.
  4. Go to Start, Control Panel and double-click Display.
  5. On the Settings tab, drag the slider bar to 1024x768.
  6. Click OK
  7. Shut down and reboot.
If the problem goes away, then you are good. Otherwise, you'll have to boot menu again (F8) and choose Enable VGA Mode.
Can't reload XP
BAD_POOL_CALLER
Try a Repair Install with your WinXP Bootable CD. If Repair option fails you will have to do a Clean Reinstall of WinXP as a last resort.
Some details:
1. Boot with your WinXP CD
2.At the "Welcome To Setup" screen, Choose the option:
To setup Windows XP now, press ENTER. DO NOT choose !!!! To repair a Windows XP installation using Recovery Console, press R. IGNORE
To quit Setup without installing Windows XP, press F3
3. Accept the License Agreement and Windows will search for existing Windows installations. 4.Select the XP installation you want to repair from the list and press R to start the repair. If Repair is not one of the options, under the Circumstances you are in the next option will be Clean install
5. I this does not work it might be your memory --download and burn to cd memtest (http://www.memtest86.com/) and test your memory for errors.
32helpful
6answers
Installing Win XP, F8 key to agree to EULA wont respond
Check for an F Lock key on your keyboard.
By pressing it, it should activate your F Keys and F8 should work as advertised.
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
