The Shared Key needs to be the same on the access point and on computers trying to connect to it. So if you're setting it on the router, use whatever key you want (there are some requirements, depending on whether you're using WEP, WPA or whatever), then copy the router key so that you can type it in on the computers.
Setup steps:
1. Connect the computer to one of the four LAN ports on the router.
2. Open a web browser on the computer.
3. In the address bar of the web browser, type http://192.168.2.1
4. Click Login in the upper right-hand corner of the page. The router does not ship with a password, so just click Submit.
5. Click on Security in the left-hand column under the Wireless heading.
6. Use the drop-down menu and select "WPA/WPA2-Personal (PSK)".
7. Select either WPA-PSK, WPA2-PSK, or WPA-PSK+WPA-PSK2 as your Authentication; doing this will set the Encryption Technique automatically.
8. Enter a word or group of characters in the password (PSK) box. The Pre-Shared Key must be 8 to 63 characters in length. Note: The PSK (Pre-Shared Key) is case-sensitive ("A" is different than "a").
a. Unchecking the Obscure PSK box will allow you to see the security key that has been typed.
9. Click the "Apply Changes" button to save the settings.
Any/all wireless computers that connect to this network will be required to have this Pre-Shared Key (password).
4. You must log in with a password to make changes to your Router's settings. If you have not yet set a custom up a password, leave this field blank and click the "Submit" button.
5. Click the Wireless > Security link from the page menu on the left-hand side.
6. On the Wireless > Security page, you can retrieve your password(s) from the fields to the right of the Pre-shared Key (PSK) > entry.
7. Uncheck the Obscure PSK box to view and retrieve your password(s).
8. Re-check the Obscure PSK box to obscure your password(s).
Hope this information will help. Thank you for using FixYa!
7. Select
a. Un checking the Obscure PSK box will allow you to see the security key that has been typed.
1. Connect
2. Open
3. In
4. Click
5. Click
heading.
6. Use
7. Select
8. Enter a word or
a. Unchecking the
typed.
9. Click the "Apply
