Caveat: I am not a tech, I just read through the Mitsubishi service manual, and have worked on different model TV that I have owned (older model of this one) I am a little unclear on the second set of lights but I think the combination *may* indicate that the lamp fan is not starting (there are two fans though), if the blinking red is the status light. It is possible the connector for that got jostled during the trip, something fell into it from being on the side (wire or loose something) and is blocking it from spinning now, or a module unseated a bit,and is loose, or the lamp is no longer seated correctly (though the lamp light does not appear to be on) or none of these. :) These are just guesses.
Be careful if you open it up, due to potential for shock. Wear gloves, and power it down first (then unplug). Reseat any fan connectors.
Google: I used "wd-65735 status lights" to find a service pdf , it's for V39 chassis (several models)
From page 24 of Service Manual :
3. Error Code Operational Check
Note: The TV must be in "Shut Down" and not have been switched Off, to perform the Error Code Opera- tional Check. When the TV is switched Off, the code automatically resets to "12" No Error.
Pressing the front panel "INPUT" and "MENU" buttons at the same time, and holding for 5 seconds, activates the Error Code Mode. The "TIMER LED" flashes denoting a two digit Error Code, or indicating no problem has occurred since the last Initialization.
Note: The front panel buttons must be used, NOT those on the Remote Control.
Page 24
MODELS: WD-60735 / WD-60C8 / WD-65735 / WD-65736 / WD-65835 / WD-65C8 / WD-73735 / WD-73736 / WD-73835 / WD-73C8
4. Error Codes
The Error Code designations indicating malfunction, or no malfunction, are listed below:
ERROR CODES
Code
Description
Most Likely Cause
12
No Error found
17
Communication loss, TV Micro - Engine (3.3V-ENG-SDA & SCL)
Engine Failure
18
Engine will not accept data (ASIC-READY signal from Engine is not detected).
Loss of 12V from PWB-POWER (Loose PE or PE2 connector); Bad Color Wheel (Loose J6 or J7 connector); Engine Failure
32
Lamp cover is open.
Lamp Cover Switch; Loose CD connector
34
Lamp turns Off while the TV is playing. Lamp failure
(Lamp Enable signal from engine is lost)
Lamp Cartridge Failure
36
Exhaust Fan failed.
Loose J4 connector
37
Engine (DMD) fan failed.
Loose J5 connector
38
Lamp temperature abnormally high.
Poor Air Circulation; Loose J3 connector
39
DMD temperature abnormally high.
41
Standby Supply Short is detected. (5VS or 3.3VS)
PWB-MAIN Failure
42
Sirocco fan failed (Lamp fan).
Loose J8 connector
44
Check for disconnected DVI cable between PWB-DM and Engine. (Engine pulls DVI pin 14 Low)
DVI Cable unplugged
48
PON-SHORT 3.3V switched supply short
PWB-MAIN Failure
57
Ballast communication problem (ballast to chassis)
Loss of 340V from PWB-POWER (PL or CJ1 connector); Loose FB or CJ3 connector; Ballast Failure
61
No LAMP-EN output from the engine to the ballast
66
Lamp did not turn on at P-ON sequence
(No Lamp inserted)
(Disconnected cable between ballast and lamp) (Lamp-Enable goes to DM but not to Ballast)
Loose CJ4 connector;
No Lamp Inserted;
HV connection or lead wire to lamp; Lamp Cartridge Failure
Code 34(1) - Lamp Enable is generated to activate the Lamp
Code 57(2) - Lamp Enable is generated during P-ON sequence, but no Lamplit signal is received from the Ballast. Code61(3) -NoLampEnableisreceivedattheDMandBallast.
Code 66 (4) - Lamp enable is received at the DM but not at the Ballast.
4. Error Code Log
The Error Code Log - may be helpful to retrieve the code for an error the occurred in the past. To access the Error Code Log: Press <MENU> <3-5-6-4>
SOURCE: Mitsubishi WD-62628 power shuts off!
You most likely have some faulty capacitors on the power module. You can easily identify a bust capacitor. They will have swollen tops. Here is a sample pic:
Check the specifications of the faulty capacitors, and getthe replacements from your local electronics shop. If you are comfortable withthis, you can use a pair of needle nose pliers to G-E-N-T-L-Y pull out thedefunct capacitors. Once that is done, solder in the new capacitors carefully. Ifare unsure how to do this, try to get a friend who knows this kinda stuff to doit for you, or get a qualified technician.
Warning: If you do not have a background inelectronics repair, or are inexperienced, get a qualified technician to do itfor you.
REMEMBER there are very dangerous voltages inside a TVthat can KILL. Be sure to work SAFE when dealing with electricity. DISCONNECTTHE POWER BEFORE YOU DO ANYTHING.
If you want to go in for a long term solution, youcan easily replace the whole power board. You can get spare from HERE.
They also offer FREE online technical advice as you do the DIY..
Hope that helps!
SOURCE: blinking green timer light
I purchased my WD 62725 in January of 2005 and have had way too many problems with something costing this much. My green reset button is now blinking and I have read and tried all of the suggested solutions. All of them have failed. I sure think Mitsubishi should be held more responsible than they seem to be. Some one suggested a class action lawsuit. I would sure join one. Jack P
SOURCE: Hitachi 50ux58b
If you have Hitachi model number 50UX58B, 60UX58B, 50UX58K, 60UX58K, 50SBX78B or 60SBX78B and you have the following symptoms you may want to grab a repair kit from www.TvRepairKits.com. They have put together a kit that includes the parts and instructions to fix these models. This is a fairly common problem with the above model numbers. It is typically caused by a blown capacitor and pico fuse. Again, you can get a kit from the above address.
Here are the symptoms...
Primary Symptom: No Audio or Video. Power light will come on briefly then shut off.
Other Possible Symptoms : The green LEDs on the circuit board light up for a few seconds then turn off.
Hope this helps,
SOURCE: STATUS LIGHT SOLID RED ON 73 DLP MITSU MODEL WD73735
The colorwheel is your problem. To confirm this, unplug the tv, then listen thru the air vents in the back as you plug the tv in. You will probably hear a ticking sound. If you do, that is the colrwheel. If the colrwheel is working, youwill be able to hear it "spin up". It will be a sudden high pitch whine. Let me know if I can be of further assistance
