I have a New Holland Haybine 310. During the 4th cutting the bales were so loose because of the small amount of hay that the spiked wheel wasn't measuring well and we were getting up to 8' long bales. I had my boy manually trip it when he thought the next bale was long enough, but immediately after the mechanism tied the new bale, it snapped the shear pin at the flywheel. Now it snaps the pin immediately after it ties the next bale. Any ideas what we may have done and how to correct it? Bud Smith, Lima, OH
SOURCE: 2001 F-250 4x4 super duty steering problem
sounds like the problem is in the valving in the steering box. You may have to get a new steering box. i would get it checked.
SOURCE: I can feel every crack I roll over 1995 Mercury Grand Marquis.
i see you have replaced everything on front end but one thing, the shocks,a good set of gas filled shocks will give you a better ride..
This problem can be caused by:
bad c/v joints
bad strut plates
loose steering bracket
caliper bolts
wheel bearings or knuckle
SOURCE: fix front tie rods and front wheel bearings
fix it or park it. it will come off quicker than you think if driven
SOURCE: I have a 2004 pacifica,
I have a 200 4 Pacifica with the exact same problem. I was also a Chrysler service tech for 13 years. The pacifica has a history of the stabilizer bar's and bushings being a problem. Go to a reputable mechanic or alignment shop and ask them about this. Make sure and ask for the old parts when the job is complete. Give them as much info on the problem as possible and if they don't mention the stabilizer bars, ask them to check. I'ts a widely overlooked problem that usually fixes the situation. It did mine.
You may have this
posted in the wrong product category. Please select another category
appropriate to the problem and re-post the problem so the correct
expert will see and respond to the question..
This is for
car and truck problems related to Factory Installed Systems not
add on aftermarket systems.
This post
can't be removed or moved, please re-post the question in the correct
product category. Thanks
I'm
sorry but I believe you have this posted in the wrong product
category? Please re-post the question in the proper category if this
is the case, otherwise you have my apologies. This is the car and
truck problem category
