Its an alcatel one touch idol mini. last app i installed was avast a couple of hours before. screen is black, no button works, doesnt even charge. please help.
SOURCE: The screen has frozen, it starts up but the screen fails to respond..
Try calibrating your screen. Please use the stylus to calibrate!
The fastest way is to be on the slide-lock screen & hold the side volume button in the Up position until
"Press volume down key to check" comes up onscreen. This may or may not work on all firmware versions
on the current i9, but works on most. Make sure to hold the button firmly in the Up position. You will first
see the normal volume speaker icon show onscreen and the volume rise, but just keep holding it Up, and
eventually you should see the pop-up box noted earlier. The moment you see that pop up onscreen,
immediately press the side volume button in the down position. A white calibration screen should now
show & you can calibrate the touch screen using the stylus. Try to tap as close to the center of the little
pulsating icons as possible, as this will more accurately calibrate your touch screen. If the calibration
screen didn't come up using that method, then you can get to it from the Main menu screen.
Select "Settings", then select "Pen calibration", & follow the previous instruction.
For full help topics I have a cd available for 10 us dollars. Has 100's of mp3 ring tones wallpapers, and java games and opera java browser. Guaranteed help on every question ever asked on these phones. And all settings for all cellular services. I have answered 100 questions with this CD. If interested contact [email protected] Pay Pal only, will send out First CLASS Mail in padded envelope. If interested I will send Pay-Pal invoice that can be filled out and returned with instructions. Guaranteed safe transaction.
SOURCE: Tracfone screen says "charge complete", phone won't turn on.
remove battery for a few min. then reinstsll and charge again
SOURCE: Samsung Pixon touch screen frozen
The issue of touc screen freezing in he M880 is mostly due to fault in the contact. The screen contact is just below the volumen control buttons on the right. I inserted a fingre nain where the volume control is and pulled up the screena wee bit. near the volume up botton, I then inserted the tip of a tooth pick. It worked and the touch sensitivity is just as new :)
SOURCE: my java applications on my nokia 6300 cannot connect to network
Here is what to do : In opera mini check what type of connection is been set . There are to types [HTTP , SOCKET] . Just try to switch between them and you'll solve the problem . For me [SOCKET] is always better , because [HTTP] takes long time to load a page . If that didn't solve the problem , then in the phone , go to SETTINGS and make sure that all applications are allowed to use your preferred access point as default for Applications .
your rating is very important for me , that's why I've helped you .
good luck .
