Fitbit One Activity Tracker, Burgundy Logo
t
theo Posted on Oct 26, 2014
All my fitbit does is show the battery strength nothing else what is wrong?
Its just stuck on the battery signal strength
What is indicate from the symbol of low battery
A simple circuit looks at the voltage that the alternator is producing, and turns thebattery light on if it is low. The battery light indicates a battery charging problem.
Aria shows a low battery symbol - Fitbit Community
https://community.fitbit.com/t5/Aria/Aria-shows-a-low-battery-symbol/td.../2685108
May 2, 2018 - 2 posts
My scales have been working fine, but keep showing the battery low sign even when new batteriesare put in. The scales would work for one ... Battery Symbol with Exclamation Mark
Oct 2, 2016
((•)) <--- this symbol is flashing above my battery
Jul 27, 2016
Solved: Alta Battery Display Malfunction
May 16, 2016
Solved: Battery Symbol with Exclamation Mark
Nov 20, 2015
More results from community.fitbit.com https://community.fitbit.com/t5/Aria/Aria-shows-a-low-battery-symbol/td.../2685108
My fitbit is charge. But my fitbit is not working. I pushed the button and its shows nothing
The battery is very small and it could be easily over charged. If that is the case, it will show charged and it wont work. You cannot replace the battery yourself.
On my iPhone app the Fitbit shows a battery icon In orange after one day of use. Above this icon there is a green symbol ((.)). Fitbit is working fine but what does this mean.
The Status Bar that is displaying itself related to your FitBit is the Battery Life/Charge Level Indicator for your FitBit, it changes Colors as the battery reaches different stages, it'll be different colors with low or critically battery life remaining for example. Your Fitbit manual will give you a more accurate answer as to what each color means but usually Green is associated with a Full Charge and Still Shows Green Doen to About 30%-40% Battery Life Remaining, Then It’ll change to Yellow or Orange until it gets critically low which is about 10%-15% and 10% or less will most likely be RED to let you know it’s time RON Charge orb go without the FitBit because it’s almost dead. Most Bluetooth Devixes Show their Battery Status or Charge Level on your phone, hopefully this helps and feel free to let me know if this helped by clicking the icon to let me know this was helpful. You're welcome RON leave a review or follow me as well. All the same, I hope this helps you out.
I let my fitbit battery die and now the clock is wrong and I do not know how to set it. can you show me how to set it?
Charge the fitbit and then connect it to your PC or Mac. When the fitbit has completed syncing, the time will be correct based on the computer time.
My fitbit 2 charge is showing wrong time and date.how do I reset it
completely shut down the phone/device you sync with and the Fitbit. When re-starting, make sure there are no other devices that are trying to connect to the Fitbit, and that the app on the device you're syncing with is up to date.
this usually works. If not - contact Fitbit Customer Support.
How do i charge up my fitbit?
      To charge your tracker:
      1. Remove your tracker from the wristband:
      2. Insert your tracker into the charging cable. ...
      3. Insert the charging cable into a USB port or UL-certified USB wall charger.
      4. Your Flex's LED indicator lights will pulse to show the battery level every few seconds.
      More items...
      Help article: How do I charge my tracker? - Fitbit Help
      https://help.fitbit.com/articles/en_US/.../How-do-I-charge-my-tracker Fitbit
    Feedback
    https://help.fitbit.com/articles/en.../How-do-I-charge-my-tracker
    FitbitDec 12, 2015 - To charge your tracker: Remove your tracker from the wristband: Insert your tracker into the charging cable. Insert the charging cable into a USB port or UL-certified USB wall charger. Your Flex's LED indicator lights will pulse to show the battery level every few seconds.
    Fitbit Help - Getting Started
2answers
My battery is charged but showing empty on computer. I restarted it but still showing empty.
with computer turned off take out battery and wipe off contacts then reinstall battery. If it is still empty after letting it sit a bit to see if it is charging you either have a bad battery or the charger in the computer is bad . that is an expensive fix. usually not worth the money unless you have an expensive computer and then that probably would not happen.
2answers
Why does a 8 appear upon start up on the screen?
That number is the signal strength indication. IF you get four beeps when that shows up and it could be E instead of 8, the unit has detected something wrong.
BlackBerry Curve 8520 signal swing
#1 Your BlackBerry does not have sufficient Power
Check the battery charge level as shown by the battery icon on the top left of the home screen. No Power - Battery Charge Indicator does not show a charge or is very weak. The battery icon may be red. Charge the battery.
#2 You are Out of Network coverage area
Check the Signal Strength Indicator on the home screen. (1 to 5 bars, as shown below, indicating signal strength). If there is no signal, you may be out of range of the network.
If you are sure you are in range of the network, but show no signal strength, press Alt-Right Shift-Del at the same time. This will cause the BlackBerry to reacquire a network connection.
The process for this procedure is:
  • Press Alt-Right Shift-Del (The Del key is also the Backspace key.)
  • The screen will go blank, and an hourglass will appear. Wait for the hourglass to go away.
  • The startup screen will appear. Wait for it to go away.
  • A screen that says Verifying Security Software will appear. Wait for it to go away.
  • Check the Radio Tower icon.
If you are in Coverage Area of your Service Provider, You will get the network.
#3 Your Data plan is switched Off.
I have samsung monte when i entered the youtube and going to play the video it show connecting but then it show not connected
Nothing wrong with your phone. It is the signal strength and the speed. Unless you switch to a fast and reliable service provider you will continue to have this problem. Go for 3G service provided by MTNL/BSNL.
Top Fitbit Tools & Hardware - Others Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Fitbit Tool and Hardware - Other Expert? Answer questions, earn points and help others
