Go to settings and turn wifi on from your leapPad, then search for available networks till you find your home wifi, then enter the password and your connected!
camera distance may be too far from wi fi source ie router or access point ? possible solution use a wi fi range extender.
Neighbours Wi Fi interfering with your WI FI . possible solution change the channel used by your wi fi from auto to channel 3 or channel 6 . This ensures channel spacing from neighbors if they are on auto as well . Setting in wi fi access point or wi fi router
Ensure that you have the appropriate network key code needed to
enable you to access a secure Wi-Fi network.
If you are connecting to a secure Wi-Fi network with MAC address
restrictions, you will require pre-authorisation for the router. You
will need to find your Samsung Jet's MAC (Media Access Control)
address. This is a 12-character code which may be needed by the network
controller to enable the phone to connect. See Getting the Samsung
Jet's MAC address below.
You can get to the Wi-Fi
application either via the main menu or using a homescreen Wi-Fi Widget.
To get to the Wi-Fi application via the main menu, press the MENU
button (either on the home screen or the hexagonal button beneath)
In the main menu, swipe your finger sideways to go through the
menu
pages until you see the Wi-Fi icon. Press to
select.
The Wi-Fi application opens.
Alternatively, to
use the Wi-Fi Widget, from standby, press the home screen. The Widget
toolbar opens up.
Scroll down to find the Wi-Fi Widget icon. Press the Wi-Fi
Widget. The Wi-Fi Widget will pop
up on the main screen.
Press the Wi-Fi Widget on the main part of the
display to launch the Wi-Fi application. The Wi-Fi application opens.
Once
in the Wi-Fi screen, press the large Wi-Fi button in the middle of the
screen to turn it on. Wi-Fi is activated and the
button turns blue.
Press SEARCH Nearby Wi-Fi access points (APs)
will
appear as small circles on the display, with their names next to them.
Press the circle representing the Wi-Fi Netowrk you
want to connect to. An options panel appears.
You can press
CONNECT to
connect to the network or
press ADD if you want to add it to a list of preferred
networks for easy access later.
You are taken into a settings
menu for the Wi-Fi access point. If the Wi-Fi access point requires a
network key code,
scroll down to the Network Key panel. Press
to select.
The numberpad appears. Type in the network key code
and press DONE. You are returned to the previous settings screen. Press
SAVE
A list of connections
appears. Press the back arrow button
If you initially pressed
CONNECT, the phone will
connect to the selected Wi-Fi network and a confirmation message will
appear. The display now shows the new connection, illustrated by blue
dots linking the circles onscreen (Figure 15).
If you initially
pressed ADD, you will be returned
to the Wi-Fi screen. Press the circle representing the Wi-Fi network you
want to connect to. A pop up panel appears.
Press CONNECT. You
will be connected and the
connection illustrated onscreen.
Press the back button to return to the home
screen.
From the home screen press MENU to enter the main
menu (Figure 1).
In the main menu, press INTERNET
Choose which
browser option you want (Home, Enter URL, Bookmarks,
etc.) (Figure 18) and press to select. If you press Home you will be
taken to the pre-loaded home page.
If required, use the
numberpad to type in an URL or scroll a list to
select bookmarks. When an URL is completed press GO.
Alternatively press the bookmark you wish to access. You will taken to
the web page requested.
Activate Wi-Fi and press SEARCH,
as before.
When the Wi-Fi access point you want to connect to appears on
the
display (Figure 8), press it to select.
A pop up options panel
appears (Figure 9). Press DETAILS
Details of the Wi-Fi access
point appear onscreen.
Scroll down by dragging your finger up
the screen. Towards the
bottom of the settings list, DEVICE MAC appears, with a
string of 12 charactesr beneath (Figure 21). Each handset has an
individual MAC address, and this panel will display your Samsung Jet's
unique Mac address.
Make a note of the MAC address. You will need it if you want to use
the Samsung Jet's Wi-Fi to access a secure Wi-Fi network using MAC
address restrictions. This can be added into the wireless router
settings access list.
Please go to mobile setting and turn on wi-fi on your mobile phone.
Now wi-fi network is on.
below your are showing wi-fi connection names.
now click on wi-fi connection and connect.
now asking for password.
enter correct password and click ok .
Samsung ElectronicsFAQ00061225 I cannot connect to Wi-Fi® on my Samsung device. ... On the mobiledevice, attempt to connect to the Wi-Fi network. If you are not able to connect ...
The below info is from user manual ... downloadable version @ www.pantech.com
Connectivity This chapter introduces useful tips on how to connect to the network available that enables applications of the phone to run. Using a Wi-Fi network Connecting to a Wi-Fi network 1. Tap Settings from the applications menu. 2. Tap Wireless & networks > Wi-Fi settings. 3. Tap Wi-Fi to activate the technology. 4. Select and tap a network. You should enter the password if the network is secured. indicates a secured Wi-Fi network. 5. Tap Connect. Once the network is remembered, the phone will automatically connect to it when in range. Activating Wi-FI Connecting to a Wi-Fi network Note The icon next to each network indicates the strength of the signal. For example, indicates the signal is poor while indicates the signal is strong. Using the Easy Setting 1. Tap on the top of the home screen and drag it down, or press n in idle mode and tap Notifications. 2. Tap in Easy Setting. The icon turns red when the function is on. About network notifications You are informed by default when a Wi-Fi network is available around you. The message in the status bar indicates a network is available. Tap Network notification in the Wi-Fi settings if you do not want to be informed the availability of the network. Setting Wi-Fi networks 1. Tap Settings from the applications menu. 2. Tap Wireless & networks > Wi-Fi settings. 3. Tap Wi-Fi to activate the technology. 4. Tap Network notification if you want to know an open network available. 5. Tap Automatic connection if you want the phone to connect to Wi-Fi network automatically. 6. Tap WPS button connection if you want to establish a new wireless connection using the Wi-Fi Protected Setup (WPS). You should press WPS button on your Wi-Fi access point within two minutes. Searching for Wi-Fi networks 1. Tap Settings from the applications menu. 2. Tap Wireless & networks > Wi-Fi settings.
Mark the Wi-Fi checkbox. Available Wi-Fi™ networks are
displayed in a list under Wi-Fi networks. The available networks may be
open or secured. This is indicated by the icon next to the network name.
Tap a Wi-Fi™ network to connect to it. If you are trying to
connect to a secured Wi-Fi™ network, you are asked to enter the security
key for that Wi-Fi™ network before you can connect to it. The Wi-Fi™
connection is displayed in the status bar once you are connected.
Useful tip:
The next time you connect to a Wi-Fi™ network, the phone will remember the security key.
To enable Wi-Fi™ network notification of open networks, mark the Network notification checkbox.
To connect to another Wi-Fi™ network, just tap another Wi-Fi™ network in the Wi-Fi networks list.
To scan for Wi-Fi™ networks manually, press the Menu key and tap Scan. The phone scans for Wi-Fi™ networks and displays them in the Wi-Fi networkssection.
You can also try updating your softwares by going to the sites below;
When using a Wi-Fi network with your iPhone, you may occasionally encounter the following issues,Unable to locate or join a nearby Wi-Fi network,Weak or low Wi-Fi signal strength,Connected to Wi-Fi network, but unable to access the Internet. Tap Settings > Wi-Fi and turn Wi-Fi off and then on again. Verify that you are in range of your Wi-Fi router or base station. Confirm that your Wi-Fi router and Cable/DSL modem are connected to power and turned on. Check whether other devices (portable computers, for example) are able to connect to the Wi-Fi network and access the Internet. Update your Wi-Fi router to the latest firmware.
Connects over the last Wi-Fi network you used that's available.
If no Wi-Fi networks you've used are available, iPod touch will scan for Wi-Fi networks and show a list of Wi-Fi networks in range. Tap a network and, if necessary, enter the password to join. Networks that require a password show a lock icon () next to them.
Option to manually enter your Wi-Fi network name/SSID (if the Wi-Fi network is configured not to broadcast or be displayed to the public). If necessary, enter the password to join.
When iPod touch is connected to a Wi-Fi network, the Wi-Fi icon () in the status bar at the top of the screen shows connection strength. The more bars you see, the stronger the connection.
Wi-Fi Settings
Turn Wi-Fi on or off. Choose Settings > Wi-Fi and turn Wi-Fi on or off.
Set iPod touch to ask if you want to join a new Wi-Fi network. When you are trying to access the Internet, by using Safari or YouTube for example, and you are not in range of a Wi-Fi network you have previously used, this option tells iPod touch to look for another network. iPod touch will display a list of all available Wi-Fi networks that you can choose from. Networks that require a password appear with a lock icon ().
If "Ask to Join Networks" is turned off, you must manually join a network to connect to the Internet when a previously used network is unavailable.
Choose Wi-Fi and turn "Ask to Join Networks" on or off. If you turn "Ask to Join Networks" off, you must join new networks manually.
Join a Wi-Fi network manually. Choose Wi-Fi, wait a moment as iPod touch detects networks in range, then choose a network. If necessary, enter a password and tap Join. Networks that require a password appear with a lock icon.
Make iPod touch forget a network, so that the device doesn't join it automatically. Choose Wi-Fi and tap the arrow () next to a network you've joined before. Then tap "Forget this Network."
Connect to a closed Wi-Fi network (an available Wi-Fi network that isn't shown in the list of scanned networks). Choose Wi-Fi, then tap Other and enter the network name. If the network requires a password, choose Security, tap the type of security the network uses, and enter the password. You must already know the network name, password, and security type to connect to a closed network. Some Wi-Fi networks may require you to enter or adjust additional settings, such as a client ID or static IP address. Ask the network administrator which settings to use.
Adjust settings to connect to a Wi-Fi network Choose Wi-Fi, then tap the arrow () next to a network.
