The H5 error code in a Blue Star split inverter AC typically indicates that there is a problem with the outdoor unit. The outdoor unit is the part of the air conditioning system that is located outside the building and is responsible for releasing the heat absorbed from the inside of the building to the outside.
There are a few possible causes of the H5 error code:
The outdoor unit's compressor might be malfunctioning. The compressor is the most important component of the outdoor unit and is responsible for compressing and circulating the refrigerant.
The outdoor unit's fins might be dirty or obstructed. The fins are the thin metal blades that are responsible for releasing the heat absorbed from the inside of the building to the outside. If the fins are dirty or obstructed, the heat exchange process will be impaired, resulting in the H5 error code.
The outdoor unit's fan motor might be malfunctioning. The fan motor is responsible for turning the fan blades that circulate the air over the fins. If the fan motor is not functioning properly, the H5 error code will be displayed.
To troubleshoot the H5 error code, you should start by checking the outdoor unit for any visible signs of damage or obstruction. If you do not see any obvious problems, you may need to call a professional HVAC technician to diagnose and repair the issue.
The E6 error code indicates communication failure between the inside and outside unit. First thing to try is turning off the power which you have already done. Next thing to check is the wiring connections between inside and outside unit.
What is the make / model of your air conditioner. With out that information i cant help you with your ac repair problem. If you need anything else air conditioning related don't be afraid to check us out our AC Service and information online.
Indicating e6
BIDYUT SAHA
Inverter ac 2 tr its showing on disply e6 plz tell me wht is theproblem
Ac indoor unta blower start nahi hot
Indoor unt blower not start
