Watch the video....may b get helped to u
How to Unlock Nokia Lumia 520 from At by Unlock Code from Cellunlocker...
So the easiest way to tell right away if you are buying a locked or unlocked device is where you are buying it from. Generally speaking if you buy a phone from a carrier directly (AT&T, Verizon, Tmobile) you are buying a phone stamped with that brand and locked to that carrier.
Now factory unlocked devices exist but are primarily bought directly from the manufacturer. So for example you want a unlocked new iPhone 5s, for this you would buy it from Apple directly. Then you can use it with whatever Carrier you want (that also supports the 5s phone).
The good news is AT&T does allow you to unlock your devices as long as you meet certain requirements. I had my Lumia 900 unlocked after about a year of using it on my GoPhone account. You just have to head over to this link: To make this short you need a code you need to call your phone company
SOURCE: at&t nokia lumia 900 sim unlock
Hi
you can unlock your AT&T Nokia Lumia 900 sim lock by using AT&T Nokia lumia 900 sim unlock code .
you can get your AT&T nokia lumia 900 sim unlock code by trusted of world attphoneunlockingshop.us
SOURCE: How do i reboot my Nokia Lumia 520 windows
Click and hold down the power butting on the phone, after a couple of seconds you will be given the option to slide your finger down the phone to turn it off. Once off click and hold the power button again to power back on.
SOURCE: How to unlock a phone. Nokia lumia 520
Hi. You can unlock a Nokia Lumia 520 safer and easier using unlock code. You can get the accurate unlock code for your Nokia Lumia 520 either from your respective network provider or from any trusted vendor online like TheUnlockArena.com at affordable cost.
..............UNLOCKING INSTRUCTIONS..............
1 - Switch on your Nokia Lumia 520 without any sim card.
2 - Don't bother as to what is displayed on your Nokia Lumia 520.
3 - Compose #pw+CODE+1#.
4 - The Nokia Lumia 520 would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia Lumia 520 mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
3 - Compose #pw+CODE+7#.
The letter p appears if you press the button star(*) three times quickly
The letter w appears if you press the button star(*) four times quickly
The symbol + appears if you press the button star(*) two times quickly
The CODE you need to enter is the unique unlock code for your Nokia Lumia 520
SOURCE: where can i get unlock code for nokia lumia 520,imei :351737060551944?
Hi you can purchase network unlock code for your Nokia lumia 520 mobile from providers like Unlocking4U.com for affordable cost .You first check that whether the code is available for your country and network provider .If yes then pay for it and unlock your phone then freely use it with any GSM sim ..
