Chances are the unit is shutting down on an error code. It will shut down after three batches if either A: the unit takes too long to make ice, or B: a harvest cycle lasts too long. You can time a batch of ice with a timer or stopwatch... if you listen you should be able to tell when the "ice making" stops and the "harvesting" begins. Ice making should take about 13-15 minutes and harvesting 1.5 to 2.5 minutes. If I remember correctly the error codes are triggered if the ice making takes 60 minutes or longer and/or the harvest takes 3 minutes or longer. You can tell which error code is tripping by accessing the electronic control board. There is an LED indicator that will blink when you turn the unit on if there is an error present in the memory.
