Double-check that the power cable is plugged tightly into the back of the printer, as well; also check the power cable for any cuts or fraying. If the cord looks okay, and the printer will not power on at all, it is very likely that the power supply inside the printer has failed. You will need to either return the printer (if you are within 30-90 days, depending on your place of purchase), or contact Canon for warranty service. This is not a part I would attempt to replace yourself, as it involves soldering connections.
Might be a problem with your cord...or maybe you are using the wrong cord to download. Make sure you have the cord you received with the camera. Plug in the cord to the computer. Restart your computer. Then (with your camera turned off) plug in the cord to the camera. Start the camera and see if it connects.
For products with keypads on the control panel:
1. Without turning the unit off, unplug the power cord from the back of the product. 2. Press and hold “# and 6′ keys. 3. While holding those keys plug the power cord back in. 4. Wait until the screen goes blank before you release those keys. 5. Follow on printer screen instructions. For Box-type models:
1. Unplug the power cord from the printer. 2. Wait for 30 seconds. 3. Plug the power cable back in the printer and turn it on.
All cameras do this. As soon as you plug in the cord, the display will turn black. It is completely normal. If the pictures aren't showing up on computer, make sure the latest drivers are downloaded for your camera. Also you can use, picture transfer or kodak easy share program to download. Another way is to go to 'my computer" than either f: or g: drive should have your camera on it. You can access pictures here and drag n drop into another file.
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
make sure that the camera is connected to the pc, check for the message in the camera display, say yes to connect to the pc and check if it+s been found by the computer as a drive if don´t you have a problem with the camera. if it appers them the problem is in the camedia you need to go there and tell him that u are using usb port.
