You need to give more information. Does the motor stall when you squeze the handle? Does the spray surge and the motor run well? Does the spray surge and the motor surge as well? Does water come out of the bottom of the pump? Does nothing come out of the spray gun when the trigger is squezed?
All of these symptoms point to different problems.
What does your machine do?
SOURCE: oil for a troy bilt 2550 psi pressure washer pump
What fluid and how much is required in the Troy-Bilt 2550 power washer pump?
