Ipad will not connect to internet, stops about 1/4 the way across the search bar, I can call on Skype so it has the wifi connection.
SOURCE: hello, my Ipad hase Wifi message,but
If your ipad is connected then it might be that your router needs to reset or your internet is down. Just unplug your modem and router for 5 seconds then plug in and see if that helps it. Check if your computers can connect to the internet.
SOURCE: my wifi on my iPad
This sounds like a hard ware issue with you wifi antenna. Restore your device using iTunes. If it is still grayed out take it in for service at a local apple store or authorized service provider.
SOURCE: ipad wont connect to internet
Go to settings and then wifi if it is off switch it on and then select your wifi router and enter your password
I take it is your own wireless network, so if you look at the bottom of wireless router box usually they have the information required to log on.
If it is your office wireless network contact your system administrator to seek permission to use it and if it is accepatble they will give you the details to log on.
If it is someone else's wireless network connecting to it without permission could be considered theft so we can't really help in this case.
SOURCE: I had bought an ipad
I was very happy when I got my hands on the new iPad. I didn't notice this at first, but when I took the tablet into my backyard, and my iPhone was able to pick up my router signal without a hassle; the iPad didn't pick up the network at all. This became a nightmare for me. A friend suggested trying the "Forget This Network" reset method, which used to work on the older models, but this didn't improve the wifi range at all. Right when I lost all hope, I came across WIRED magazine and found a review of Pong Research cases, After seeing the great feedback on their products, I bought one and it finally solve the <a href="http://www.pongresearch.com/new-ipad.html">new iPad 3 wifi issues</a> . The back cover has a built-in antenna in between its layers, which redirects and boosts the signals and range, allowing me to getting connected from much further away.
