Yes you can, the S4m and Z4m both use EPL, contact www.lancerlabels.co.uk for pricing and delivery of a Z4M printer.
Home
SOURCE: zebra z4m plus printer has no display showing
We had a computer tech change the CMOS battery inside the printer and the display starts to work again.
SOURCE: zebra s4m error condtion paper out
Sounds like you will need to perform the calibration procedure.
when you access the menu system go to advanced menu, the password is 9999, use the keys to navigate to manual calibration and follow the instructions. when it states load backing this is refering to backing paper, so remove the labels from the backing and place in label path. hope this helps
SOURCE: USB PORT FOR ZEBRA Z4M
It will not work with any drivers if you do not have a parallel port. You can get a pci card that has parallel port on it for use with the zebra z4m.
below is a link for the card that cost only $9.99
http://www.gogocost.com/xcart/product.php?productid=275
SOURCE: I have Thermal Zebra Printer TLP2824, I have installed it and
The printer has firmware TLP2844-Z Zebra. This printer uses ZPL commands and not epl. ZebraDesigner can print to a file and have a format command.
download.....http://www.barcodesinc.com/free-barcode-font/
free barcode font for programs. copy into c:/windows/fonts
it will install into that folder, and just select that font in VB6 application before printing
the following EPL printer models:
• TLP 2746e..."
Special Firmware
Version
Size
E53.17.3
3 MB
http://www.zebra.com/id/products/global/en/firmware/barcode/e53_17_3.NotesFile1.File.tmp/14328L-006.pdf
download the firmware, go to the driver and "send file" and send the file *.zpl to the printer.
