Sanyo DP42848 LCD TV Logo
J
Jaime Posted on Oct 24, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
New sanyo baklight inverter making loud buzzing sound
Level 3:
Top Expert:
  • Sanyo Master 76,851 Answers
  • Posted on Oct 25, 2014
Sanyo Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
15003598
Points
237762
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
When microwave is started, why does it make a loud buzzing sound--like a Skil saw sounds?
Whirlpool Microwave Buzzing Loudly - ApplianceBlog
www.applianceblog.com/.../26531-Whirlpool-Microwave-Buzzing-Loud...
Aug 12, 2011 - 10 posts - ‎2 authors
My Whirlpool MT4155SPS-2 microwave oven has recently started to buzz loudlywhen operated. The sound is getting louder and more frequent ...
Whirlpool making intermittent loud buzzing noise Microwave ...
www.fixya.com > ... > Microwave Ovens
Whirlpool microwave ovens making intermittent loud buzzing noise related questions and answers. Ask your ... ...loud buzzing noise and it doesn't heat. i just tried it again and let it run for 1 minute. ... Question about Accuwave Microwave Oven.
Troubleshooting the Microwave: Potential Problems ...
www.appliancejournal.com/.../troubleshooting-the-microwave-potential-...
If your microwave buzzes loudly and produces no heat you probably have a defective power .... I have a whirlpool oven range and it's less than a year old. .... Humming sound stops when I open door to remove food, but when door is closed, ...
Whirlpool Microwave Ovens - Consumer Affairs
Makes a really loud buzzing noise during operation
Unit uses a Magnetron and likely a power board called an inverter to run it. Someone would have to open the unit in a way where they might pinpoint where the sound is coming from and then take action--does not of course sound normal or good to me.
A loud buzzing is coming from the back of my sanyo ds 25390 tv. picture and regular sound is fine
If it is a high pitched whine or buzz it is likely a transformer vibrating so hard it is making the noise.
There are ways to try to deal with this issue but the set has to be opened and probed to locate where it is coming from--
for example with back off and set on a plastic rod can be used to touch areas and exert slight pressure until the sound changes or goes away--then either replace the part or I have used hot glue etc to stop it.
You first have to locate the source of the issue:
find where it is coming from.
Loud buzzing and no sound in new philips hd42"
Hi:
The buzzing you hear is the inverter board trying to light the backlights, Check the inverter boards for puffy capacitors tops, There should be two of them on each inverter board..
1helpful
Loud buzzing sound on Sanyo AVM 1909
I had a problem like that so I disabled the tv's onboard tuner (input source)and now we use the cablebox's video and audio out to the video and video in jacks on the TV this will work as long as you have a cable box or sat reciever for your video and audio source and of course your TV must have video and audio inputs so it will work.
Good luck Rich
2answers
No picture
Ur LCD inverter backlight board is dead.Replaced this LCD inverter backlight board will get ur picture back.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish LCD inverter baklight board for the replacement.It a long board in shape.
1helpful
2answers
Loud buzzing noise when turning on
It sounds like a bad internal connection or a component failing. If the picture still is very good take it to a known good repair shop.
Loud sound from tv
It could be the inverter board going bad. The inverter board is what makes the back lights come on and has transformers on it that have high voltage. any time you have a noise like a buzzing or arcing you should have it checked
2answers
Television problems
Have the speakers ever been played loudly? They may have been pushed passed their capacity, in which case, it may be time for a new tv.
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
