Is there another way to know I have a voicemail without checking the lines periodically and listening for the beeps? Also when I transfer a call to another number it does not provide the callers ID only the office's number. How to I transfer the callers information?
These features are handled by the system, not by the phone. You need to ask you administrator to enable the message waiting indicator on your voice mail. When you transfer a call the incoming CLID flashes only for a brief second on the target display. I am not sure that can be changed - it depends on your Nortel hardware and OS version.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/dave_fb2c45146b845cea
Check your Voicemail
Just in case anyone still has difficulty in finding the instructions.....
Set Up your VoicemailBefore your phone can receive voicemail messages, you must set up a 4-10 digit passcode and record a personal voicemail greeting.When you have set up your voicemail, all unanswered calls to your phone are automatically transferred to voicemail, even if your phone is in use or turned off.1. Press and hold the 1 key.2. Follow the system prompts to create a password and record a greeting.
Best of luck!!
When you receive a voicemail message, a
notification with a voicemail message icon
appears at the top of your screen.
• At the voicemail notification, select Call to call
your voicemail number and follow the system
prompts to retrieve the message.
Select Ignore to clear the notification without
checking messages. The notification icon
remains on top of the screen until you listen to
the message
• When only the voicemail message icon
appears on top of the screen, select
Voicemailand follow the system prompts
