Just done a wash with no problems. Loaded another and shut the door and switched on, the door lock light is now not coming on and the mains light is flashing slowly.....help please!!
Try pushing the door in as I suspect the door interlock switch is stuck, if this dosen't work you will have to replace the door interlock switch which can be purchased from Hotpointspares.co.uk and is reasonably easy to fit as can be seen on YouTube .
Testimonial: "Hi, thanks very much for that. I have tried all of that to no avail, so will follow your advice!"
SOURCE: DOOR WILL NOT LOCK
assuming that you didfi not unwire ther door lock, the problem is probably just that the door seal just needs bedding in and you should be able to start by closing more firmly and pushing in till the door lock catches. did you properly seat the door boot on the cabinet?
SOURCE: door lock flashes
Your switch bracket or switch is either broken or you have no either to or from it. Check your switch first.
SOURCE: hotpoint bwm129 lights flashing
What mode are you starting this machine in ? I know this may sound silly and I'm trying to determe if this is a machine fault code or something else.
SOURCE: hotpoint first edition few 12p,not working
parts are free but a call out charge is made approx £80.00
