The numbers on the panel dont associate with the correct speed. When I hit 1 for the speed on the board, it goes to 1.6. How can you calibrate the proper speed to the number?
The
Calibration sequence can generally be used to accomplish the
following: 1) To reset the treadmill's speed software, if
the running belt seems to be moving faster or slower than the
speed indicated on the console. 2) To reset the
treadmill's incline software, if the walking
deck seems to be elevated higher or lower than
the height indicated on the console. 3) To synchronize the
treadmill's electronic package ANY
TIME a replacement part
(anything electrical) has been installed and is being prepared for
use. 4) This should be the first step performed when
attempting to diagnose or troubleshoot the unit.Calibration often
helps in correcting minor "bugs" in the
software (by "resetting"), before actually having to
replace components.
Before
You Begin:
You
must first determine the model number and style of
unit of the unit being worked on. Do
this by:
Powering
up the treadmill and removing the emergency stop key (usually a
magnetic plastic piece that attaches to the top, center of the
console). If
you
see "10" in the console, it is an old style
console and the "Older
Style" Calibration should
be referenced. If an "SI-1"
appears in the console, it is a newer console. The
following calibration sequence can be performed.
Note:
To change any of the current codes (if incorrect or out
of sync), use the SPEED +
or SPEED
-(minus) button(s).
Refer
to the Calibration
Chart (or the
unit's owner's manual if not on the chart) to verify that the
calibration codes on the unit (represented as "??"
below) are correct.
The
Steps for Newer Style Console Calibration
Locate the calibration area on
the rear or underside of the console (a hole, near the console's
center, that goes through to the electronics board. (This hole
should not have a screw in it.)
Insert a pencil (eraser
end), into the hole and feel around for the cal button (will
click when pressed).
Press the button 2
times (with the pencil eraser). The first click should show
CL11 in the console, the second click should show CL21.
If the process was done
correctly, and CL21 appears in the console, you are in
"calibration mode." The next few steps consists
of pressing buttons on the console and observing
settings. This will not require any other tools.
Press ENTER. CL22 should
display in the TIME window and (??) in the SPEED
window.
Press ENTER. CL23 should
display in the TIME window and (??) in the SPEED window.
Press ENTER. CL24 should
Press ENTER. CL25 should
Press ENTER. CL26 should
display in the TIME window. You should then see
the letter "E."
Press ENTER. You should see
"SS" or "55" in the console.
Push the STOP/START button. For
safety, at this point, you should step off, or be off, the
treadmill.
Push the ENTER button. The
walking belt should start to move, accelerate to maximum speed,
then stop on its own.
When the belt stops, the
incline should self test by raising to its highest
incline position, then lowering back down to its lowest
position.
Once the incline test is
complete, push the POWER button 2 times. The unit should shut off
and the console should go completely blank. If this
happens, the treadmill is done calibrating and is
ready for use.
