Samsung PN60E8000 60-inch 3D Plasma TV Logo
d
deborah wilcoxon Posted on Oct 24, 2014
My Samsung 60 plasma tv has no signal from my cable box so I connect the cable box to another tv and the box works please tell me what I can do
1helpful
I am trying to set up the above as a second monitor with an ASUS all in one.
to run a second monitor you will need the appropriate graphics board fitted
talk with a computer shop and have it explained what you want
Thin red line running from top to bottom of screen
What is this thin red line that is on my screen whenever my ...
https://answers.yahoo.com/question/index?qid...
Sep 23, 2010 - There is a very thin red line going from the top of my computer screento the bottom, ... If it's a single-pixel-wide red line from top to bottom it's a failure in ....have thin red lines running down the screen??some are thicker than ...
Thin Vertical Red Line [Solved] - Acer - Displays - Tom's Hardware
www.tomshardware.com > Forum > Displays
Tom's Hardware Guide
Jul 12, 2013 - 5 posts - ‎2 authors
hi all i am having a Thin Vertical Red Line on my Acer LED moniter ... the screen is having a part fail(cable or the screen/control board it self.).
Why is there a straight vertical line going from top to bottom on ...
forums.androidcentral.com > ... > Samsung Galaxy S6 edge
Apr 15, 2015 - 7 posts - ‎4 authors
Just bought the Samsung Galaxy s6 edge yesterday. After I charged the cellphone for the first time and turned it back on there was this straight.
How do I get back my local channels on my Vizio by rabbit ears
Make sure that you have the TV tuner set up to receive ATSC (digital) signals via "Off Air" or "Antenna". Having it set to the "Cable Ready" mode will only get you Ch 2 - 13. These settings are usually available in set up and may even allow the TV to scan for available channels, etc.
I have a Samsung Model HPT5054X/XAA 50" plasma TV. the picture went black but still have audio.I purchased a reman Y sustain board.The Y buffer boards looked good. Now when I reassembled the unit,st
Did it work with the Y-sustain board replaced? Likely if it did not work then there is an issue with the capacitors on the Y-sustain board and the power board. Check these caps for failure and replace them with the exact type. Likely the caps are blown and cause voltage loss in one or both boards.
1helpful
2answers
How do I activate Roku activation code?
You have to establish a connection to your router so the Roku can communicate .
Blue dots on black images
I can tell you that I had my plasma screen replaced in the 4th year. The tech told me that the replacement panel was much more reliable. You may be looking at replacing the plasma panel...(which may be more expensive than replacing the whole unit??).
Where do i get updates for my 43"samsung tv plasma series 4+
u can get the latest firmware direct from samsung.com and the go to http://www.samsung.com/uk/support/download/supportDownload and type your model no hope this helps thanks john
Wall signal to my tv with poor signal
check your infrared beam with this article: http://www.unique-stuff.co.cc/fixing_remote_control_check_infrared.html
there could be problems with the infrared beam emited from the device.
1helpful
Cascio Twincept alarm and hourly signal issue
Follow this link:
http://world.casio.com/wat/download/en/manual/
Rate me, please.
Top Samsung Watches Experts
 Mikey
Mikey
ADMIN Andrew
ADMIN Andrew
Are you a Samsung Watch Expert? Answer questions, earn points and help others
