Re: I can't get my mpc 1000 to play chopped samples on...
Have you checked it out from the manual. If you have get in touch with www.akai.com and ask them. they are the manufacturer and YOU ARE THE CUSTOMER.
Good Luck
Other settings
Adjusting the master level
You can adjust the level of the headphone and the stereo out by turning the MAIN VOLUME knob. The MAIN
VOLUME changes the analog signal level. This will also adjust the entire level of the MPC1000 digitally.
01. Press the [MODE] key and then the [PAD 10] (OTHER).
It switches to the OTHER mode.
02. Press the [F1] (GLOBAL) key.
The GLOBAL page will be displayed.
03. In the Master level field, set the level.
You will set the digital signal level, which will be sent out to the DA converter. The MPC1000 can output up to
32 sounds simultaneously. There is the great difference in the level when you play single sample and play 32
sounds. If you increase the value in the Mater level field, you can increase the entire level of the MPC1000 to
create more powerful sound with less noise. However, if you playback many sounds at the same time, the
level may be overloaded, which may cause distortion. If you decrease the value in the Master level field, you
can prevent distortion when you play many sounds at the same time. However, you cannot have a good
result in respect to the noise or punch of the sound. Set the appropriate value in the Master level field
depending on the application.
You could hook the output of the GR33 to something like an AKAI MPC (http://www.akaipro.com/mpc) assigning different notes to trigger different samples or sequences.
Check if the Mbox2 has an echo setting that echos the audio from its input. If you want the audio to loop through the PC then it will have to echo there instead. Check that in "Sound and devices" of the PC are all set to transfer via the MBox for voice and playback instead of the internal PC audio system.
It is not clear whether you are recording audio or MIDI. If you recorded Audio samples, you will get the same sounds back even if you change the voice on the keyboard.
If you record a MIDI sequence, and then play it back you will STILL get the same sounds UNLESS you also record the MIDI voice or patch changes so the voice is changed as it occured when you recorded it. Usually there are options taht you can enable or disable voice changes.
Simple way is MIDI out from Juno to MIDI in on MPC, then (depending on how you want to work), connect MIDI out from MPC to the in on the Juno. If you do this you MUST turn local control off on the Juno or else you'll get double triggers (internal + msg in from MPC). Now to record sequences on MPC , set MIDI to as track in setup window (on the 2500, this is accessed by pressing MODE then pad 9, then press button under the corresponding tab [on LCD]) then set your MIDI channel by port, meaning if your MIDI cable is physically connected to out A, in your LCD in bottom right corner it will show as follows: 1A. This indicates you are transmitting on MIDI channel 1; port A. Remember, MIDI IS NOT AUDIO!!!!! Since the Juno is a synth and not a workstation, all transport controls are handled by the MPC, that's pretty much it... Hope this helps a little, enjoy!
P.S. Go to mpc-forum.com its THE sh**! They also have links for their e-book I have one for the 2500 and its awesome!!!
I'm having the same problem. This is my second MPC 1000 and my first one didn't have this problem. I bought one of the first one-thousand MPC 1000's sold in the US. I loved it. I sold it for rent, boo hoo. I'm glad to have another one back in my life. But sad to see it having issues already. I've only had it for a week. I have emailed Akai regarding this issue. I'll post pack here if they give me a good fix.
Try asking these guys( they'll help even if you didn't purchase there):http://www.sweetwater.com/store/detail/MPC2500 Also I'd recommend joining this forum:http://www.mpc-forums.com/
Here is an excellent source of info:http://www.mpc-forums.com/viewforum.php?f=15 Consider joining and posting any questions you have. Forum members are happy to help and have usually had the same problems at one time or another.
You sound like you have a good grasp of what you would like to do. There are lots of videos on Youtube of people using some of the gear you mentioned. Also check each manufacturers site for forums on the gear you would like to use. The forums usually consist of members who are all friendly and have good advice and solutions for any problems you may have. Remember that even the most experienced musicians started somewhere and are all still learning and are very willing to share what they know. You might consider using a laptop with an external hard drive. I think the Akai gear is very good and has good support and expandibility. Decide first what main pieces of equipment you would like and contact as many dealers as possible to get the best price. You may be pleasantly surprised and have enough of your budget left over for something you hadn't thought of yet. Good luck and enjoy your playing. Remember to study all your manuals carefully.
If your turntables use ceramic cartridges, you'll need to use a passive interface box that converts the unbalanced ( RCA ) plugs from the turntable to balanced ( 1/4" T-R-S ) plugs to connect to your MPC1000's stereo line inputs. If your turntables have magnetic cartridges, you will need an active phone preamp, check the music retailers catalogs or on-line there are many makes and models.
If you want to mix the two turntables ( sequeing from one to the other and back continuously as in a DJ setup ), you'll need a small DJ mixer.
Hope this helps.
