Th8100r1008 is the model number
Whoever marked this solved is lacking many brain cells.
Here's an actual solution:
Try using the Date Code above the QR on the back of the panel. If it doesn't work, you add 1234 to the date code. There is no setting a custom password, so It will only ever be these two options.
Source: Called HoneyWell Support September 2021 and received this solution.
yes the silly system marks 1 answer solved , right or wrong or even endless spamming here, (a plague)
the first best answer is RTM read the manual on the stat, first, no 2 are the same (unless are) and only the manual has this answer.
A2: ask the maker how to do that, they have web page go their and ask.?
Th8100r1008????????????
vast models exist and by country (not told yet) vary.
did you look on the back of the STAT, see that label , see words Password date code?
I am reading your manual to you now , RTM
"You can also find the password (date code) by pressing MENU,
selecting Dealer Information and then scrolling down to see the
Date Code
Finding Your Password (Date Code)
You will need the thermostat password to:
• Add or remove RedLINK accessories
• Make changes to Installer Setup
• Perform an Installer Test
• Reset Thermostat to Factory Default Settings
The password (date code) is located on the back of the
thermostat (see Fig. 4"
https://www.manualslib.com/manual/107465...
one more link ,but exact match,
https://www.ussupply.com/productdocument...
Here is a link to the manual
https://customer.honeywell.com/resources/Techlit/TechLitDocuments/69-0000s/69-2761EFS.pdf
