Hi, I'm trying to find somewhere to buy a replacement part for my Makita SP6000k plunge saw...The part number is 318179-6...is there anywhere on-line i can order this?ribe your Makita Problem
Is there not a <akita Dealer near you? If not, there are a number of advertisers on FixYa who sell parts for tools. Alternately try Google, Yahoo or similar/
233479-2 is the correct ordernumber
Drukveer 11 pos 30 only a spring is responsible to push the whole machine also with the sawblade up.
The machine has had an accident or something is piece of wood or something on top in the mechanics of the machine that will block him.
This is how to solve the stiff Makita plunge saw easily!!!
I've just carried out the following steps and it's like a new saw.
Clear a table top and grab the following tools:
Philips screw driver
4mm allen key
grease- i used silicone grease
1. Take the base off the saw by removing the 4 x obvious screws.
2. If you look at the saw, you'll see that is pivots on a single pin at the rear. You'll also notice that there is a 4mm allen screw driven into that pin.
3. Remove the 4mm allen screw.
4. Fill the screw hole with grease and drive the 4mm allen screw back in (it'll force grease along the pin internally). Do this 3 or 4 times.
5. Work the mechanism back and forth as if you're plunging the saw- you'll notice that it becomes so much more easy to move.
6. Wipe away the black dirty grease that you have forced out of the pin. Reinsert the 4mm allen screw and tighten
7. refix the base and spring.
8. Job done.
This actually bugged me for ages until i finally decided to have a look and see what the issue was.
