open the safe door on the panel beside the hinges there should be a reset button, Press the button once the safe beeps, input your new code and press A or B when finished code is now reset. Make sure you check your new code with the door open. Just turn the lock, input the code press your A or B which ever you chose, the lock dial should open.
you have to reset the system
on standby mode the the botten is red press it for 5 sec it will beep once ur ps3 will turn on, keep pressing untill it beep twice. this will bring the safe mode.. you need to plug your controller.. here you can choose to reset the password
I finally get to provide a solution for something!!!
Open door with the key, press the reset button hiding on the hinge side of the door mechanism, you will hear a beep. You don't have to have the key in or out. Enter your new code, and press A. Then lock it and test your code. Robert
User override key to open safe. Then: a. Inside the open door you would find hidden a red button press this button, the yellow light will be on, input the user code in 30 seconds try 1,5,9 then press A or B to finish
b. If the yellow light keeps flashing with beeps the code is wrong( revere to user manual)
