Its got 4 things, it does. COPY, SCANS, FAXES, and PHOTO,W/ PIC BRIDGE.
Baring any damage to the load or eject trays, Check the back of the eject tray with a flash light by opening the top of your printer where you insert your cartridges. (make sure power is off first so that cartridges will not move over and be in the way.) . Next, check for any obstructions of paper, dirt, or foreign objects.
Next if there is nothing to be found, use a pencil eraser and a couple cue tips and rubbing alcohol to clean residue that builds up on the rollers where the paper feeds through. Screenshot
Close the top, make sure that the load tray is not damaged and is inserted properly. (You can remove the back 2 screws on the load tray and get access to the inside to check for any other obstructions and cleaning.)
SOURCE: Lexmark E238 prints about two thirds of a page and stops
Please follow the instruction given in this link:
clear the paper jam as given in this link:
http://support.lexmark.com/cgi-perl/knowledgebase.cgi?ccs=37:1:0:512:0:0&framed=&docid=ENUS25568&relevance=1
SOURCE: Lexmark 4300 not loading paper correctly
Look down the paper feed into the printer you will see one white plastic roller. Find a cotton bud and soak the end in methylated spirits and poke it down and wipe the roller. make sure you wipe the whole circumference of the roller. This removes any grease that has come off the paper onto the roller and allows the roller to grip the paper better. I have done this once and have not had a recurrence of the problem.
SOURCE: lexmark x342n printer paper jam
Remove the jammed paper by gently pulling it straight out of the MFp
Please contact Lexmark Technical Support for additional assistance. NOTE: When calling for service you will need your printer model type and serial number. If you need help locating this information, click here.
SOURCE: i have a paper jam in my lexmark x5650
hi try firstly to open the paper mount and then put ur hand to see if there is a paper jam there if not, try to open the color cartridge mount and remove the colour cartridge and install it back again if not, try to turn it off and on again.
SOURCE: My Lexmark X5650 all in one printer displays a paper jam error
Inspect entire paper path for even a little shred of paper. All it takes to block a sensor, or hold down a "finger". if nothing at all, could be one of the sensors are faulty or unplugged.
Leading cause of paper
jams is debris / foreign objects that accidentally fell into the paper feed
area. Please try this approach to fix the problem:
I have updated the link to Lexmark 5650 all in one software installation with the OCR included.
https://drive.google.com/folderview?id=0...
