How do i reset to original settings
Hello, Factory Reset is done by turning the phone off, holding the volume up button, holding the home button and then holding the power button till the phone vibrates and you can let go of the buttons. Use volume up and down to move through options and power button to select (don't have to hold, just press once). Select "wipe data" and then "factory reset". Select "yes" to delete all user data and wait for format to complete. Then power off then on and it should be back to original settings. Hope this helps.
Menu
Path Method:
1) From the Start Screen, press the Menu button and select Settings.
2) Select SD & phone storage.
3) Select Factory data reset.
4) Select Reset phone.
You will be prompted again, and select Erase everything.
The device will reset and restore the device to the original
factory settings.
Steps to Restore Original Settings
This resets some of the settings to their original values. After resetting, the device may take a longer time to power on. Documents and files are unaffected.
