20A125/250V wire diagram
I've copied instructions from an Amazon review.
worse than worthless and border on dangerous. Be forewarned, and allow some time to install it correctly; and don't expect any help from the included paperwork.
IMPORTANT THINGS TO KNOW:
- There is no ON/OFF indicated on the switch or the instructions, so there is no way to know which direction is on or off. The picture included is upside down, and shown in the OFF position. If you install it with the switch on top, it will work intuitively with the switch up for ON and down for OFF. (Should be common sense, but doesn't say it anywhere, and the text on the device and photo suggests otherwise.)
In short, here's what the directions should say:
Before you begin -> Leave yellow sticker over top connections unless you want to add downstream GFCI protected outlets/lights - that's straightforward.
1) Strip all connections to 1/2", and use the holes on back of receptacle for direct connection.
2) Connect wires from breaker into terminals in back of switch/outlet. (Hot=Black-Gold; Neutral=White-Silver)
3) Connect white wire from light into extra hole next to the white wire from breaker.
4) Connect one short black wire from outlet into the hole next to black wire from breaker.
(this means all four holes are now filled)
5) Connect remaining black wire sticking out of receptacle directly to the black wire from your light.
6) Ensure all ground lines are properly connected.
7) Push into box, install cover plate and enjoy.
NOTE: This will result in the GFCI working properly, with no GFCI protection for the light. This is the recommended install, so that if the GFCI trips you won't be in the dark. If you want GFCI protection for the light as well, simply modify step 4 and insert the black pigtail into the hot terminal under the sticker.
The directions offer myriad ways to connect this, but are incredibly hard to decipher because the text does not agree with the diagrams. I believe that diagram B1 was the one that 95% of people will need...
