Press the button and the alarm keeps going off press to unlock doors alarm goes off press to lock doors alarm goes off
SOURCE: can't unlock doors without alarm going off
If you lock the car from the outside with the key your alarm will not go off this happened to me too
good luck with buying a new keypad they're over 150 each
SOURCE: 2005 dodge durango key fob
Hello and thank you for choosing fixya.com. I would suggest taking your vehicle to a local auto parts store and request to have a diagnosis done. (while auto stores vary, this is usually a free service and only takes a couple minutes to complete) to see if any codes are brought up. If so, the representative can tell you what the codes mean, and what needs replaced or repaired. Let them know of the situation. Even if no codes show up, ask them to clear the codes. If this does not work, do the following. 1: make sure that the batter in your key fob is inserted correctly, and that it is the correct size and type. 2. Disconnect the + Positive cable on your battery. This will reset your the vehicles computer. Maybe this will allow the vechile to code up with the fob. If not, I would take it to dealership, or backto an auto part store for further assitance.
I thank greatly for choosing fixya.com. I hope this information is useful to you and helps you get your fob working again. Let me know if you need further assistance, or have any questions or comments. Feel free to rate this information at your earliest convenience.
SOURCE: The key of my honda 2006 does not work upon
the key fob remotes need to be reprogramed or have the battery checked... make sure to have all key fob remotes present when reprogramming...
SOURCE: can not lock car by key remote . toyota rav 4 53 plate
If your car has an alarm with a separate remote, it is a separate system and it is probably self-arming. When you lock the doors with the key central lock, the alarm gets armed by the RAV4 being OFF and the door locking action. When you unlock the doors with the key, the alarm is still armed because the key is not comunicating with the alarm just the cars factory keyless system.
SOURCE: Alarm Issues
I have been having this same issue for the past 6 months. So far no one can give me an answer that solves the problem. I have done several things unsuccessfully 1) changed the battery (still happens) 2) flipped the valet toggle switch under the steering column (still happens) 3) I lock the doors using the automatic lock button on the driver and/or passenger door (the alarm will not self-activate and go off, but this still doesn't solve the root problem with the alarm)
