HP Officejet Pro 8600 Logo
A
Anonymous Posted on Oct 20, 2014
Getting lines on copys and scans
Getting lines on copies and scan images...
Gary Lesperance
Level 1:
New Friend:
Problem Solver:
  • Contributor 4 Answers
  • Posted on Oct 23, 2014
Gary Lesperance
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
Questions
0
Helped
982
Points
11
If they are continuous vertical lines then I would assume you are using the document feeder. If this is the case then lift the cover and thoroughly clean the small narrow glass section on the left. If that does not help then shut the printer down by pressing and releasing the power button. After it is completely shut down, wait 30 seconds and turn it back on again. That should take care of any dirt issues or power fluctuations causing the lines. If you are still having issues and also getting those lines on regular print jobs, then check for excess ink in the paper path.
Walter Raymond II
Level 2:
Sergeant:
  • Expert 191 Answers
  • Posted on Oct 21, 2014
Walter Raymond II
Expert
Level 2:
Sergeant:
Answers
191
Questions
Helped
53640
Points
560
Clean or replace the faulty print heads
Bertus
Level 2:
New Friend:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • HP Expert 177 Answers
Bertus
HP Expert
Level 2:
New Friend:
Cheetah:
Answers
177
Questions
Helped
23454
Points
289
While on remove power cable from printer wait 2 min, attach power cable again, , or scan glass is dirty
2 Related Answers
Anonymous
  • 541 Answers
  • Posted on Oct 27, 2009
SOURCE: Unable to scan. Keep getting,
you machine appears to not have the ability to scan. this was an option on most machines. you will have to use another machine to do this.
Anonymous
  • 3085 Answers
  • Posted on May 19, 2010
SOURCE: Have a brother MFC-680CN fax machine, which photo
Open up the feeder and clean the scanner gllass
How do I get rid of the lines when I make copies. It dose not happen if I print a scan
If you are using the ADF ( automatic document feed ) for your copies, raise the scanner cover and clean the strip window to the left of the main platen. If you are using the platen for copies and getting lines where scans are clean - you have a physical issue and it should be checked out by a technician.
2answers
Bizhub C652 has horizontal lines.
Print quality is good, b&w copy is good. When i make a color copy the machine makes blue lines or bink lines. This is a brand new c452.Scan to PC is ok, print its ok only copy. Lines are vertical.ea2265a7-6bf2-4ab0-abb0-94d103145c4c.jpeg
BLACK MARK ON THE COPIES OR SCANNED IMAGE
Clean the slit glass under the document feeder. Lift the feeder and find the thin piece of glass on either the left or right side and give it a good cleaning - you marks will likely go away.
Here is a how-to for removing lines from Sharp copiers.
How To Remove Lines from copies prints on Sharp copier
When scanning and copying get lines
clean the scan glass,it's usually a .5 to1 inch strip of glass that the paper runs over while it is scanned and it probably has white out or something similar on it
Scan and copy lines
using PRT screen and menu find clen function and try if this feature will fix the issuw.
Change the cartridge if no results.
Copying problem
could u plzz be more specific abt the line in the paper, i wish to know do u have the same issues if you are printing from the computer as well.
Try the following steps...
1) open the lid of the printer and clean the scanner glass
2) scan a document to the computer and check if you are getting the line even on the scanned image, if yes then its an issue with the printer
1helpful
Facing copying problem from scanning section
Although you didn't specify the scanner model, this solution should work.
If the scanner has a top feeder, open it.
You will see a thin strip of glass, either to the left, or right of the large scanner glass.
There is most likely a small spec of ink, white out, etc on it.
Clean the strip glass with rubbing alcohol and the line should go away.
2answers
Brother dcp 7020 Scanning to e-mail
with Brother -photo capture-copy-fax-scan machine, I can do except scanning. Please show me how to enable scanning
Photos
Does this help? You obviously have to insert the media type into the media slot on the far right.(omoademola) Using the top control panel Printing tasks Scanning/Copying/Faxing tasks Troubleshooting
The top control panel lets you print an image from a photo card, scan a document or image, and copy a document or image with the press of a button.
Button/Light: Function: 1 Power : Turns the All-In-One on or off. 2 Copy: light Illuminates when Copy Mode is selected. 3 Mode: Changes the copy, scan, or photo card mode. 4 Scan: light Illuminates when Scan Mode is selected. 5 Photo Card: light Illuminates when Photo Card Mode is selected. 6 Rotate: Rotates the image 90 degrees. 7 LCD Panel: Number of Copies- this changes the copy count. Note: This feature is not active in Scan Mode. 8 Display: Shows copy, scan, and photo card selections. 9 Resize: Enlarges or reduces the size of the image. 10 Page Preview: Shows a preview of the output. 11 Select: Secures an option. 12 Menu: Provides options for image. 13 Arrow : Scrolls left, right, up, or down. 14 Stop/Clear: Cancels a print job or clears a selection. 15 Color Start: Initiates color copy, scan, or photo card output. 16 Black Start: Initiates black copy, scan, or photo card output.
k24674
Grand Canyon Tech
Grand Canyon Tech
