Question about Kenmore 79012 / 79014 / 79019 Gas Kitchen Range
I cannot unlock the cooktop on my Kenmore gas range. There is no lockout button, only Select Clean and Stop/Clear. Neither one of which unlocked the cooktop. There is a little padlock looking symbol t
I cannot unlock the cooktop on my Kenmore gas range. There is no lockout button, only Select Clean and Stop/Clear. Neither one of which unlocked the cooktop. There is a little padlock looking symbol that says cooktop lockout, but there is no button. There is another one for the oven, but no button. How do I unlock the cooktop?
  • Ronald Rissel Oct 21, 2014
    Hi Anonymous, I want to help you with your question, but I need more information from you. The model number given in the question is either wrong or incomplete. Please check that model number. Usually, on Kenmore ranges, you can find the model # and serial # on either the left or right side of the storage or warmer drawer. Open the drawer and look on the frame of the range for a label. On a few ranges, the label is affixed to the frame between the oven door and the drawer.
    As an alternative, please post a clear picture of the control panel.
    - Ron
    New Friend:
  • 3 Answers
Your best bet is to unplug the stove and plug it back in again and hope that clears the lock
Posted on Oct 21, 2014
    Master:
  • Kenmore Master
  • 710 Answers
I'm sorry, but the model number given in the question is either wrong or incomplete. Please check that model number. Usually, on Kenmore ranges, you can find the model # and serial # on either the left or right side of the storage or warmer drawer. Open the drawer and look on the frame of the range for a label. On a few ranges, the label is affixed to the frame between the oven door and the drawer.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
5 Suggested Answers
6ya staff
SOURCE:
Anonymous
SOURCE: "Cooktop Locked"
We found the manual. Held the button down for 3 seconds and it turned off. Felt like idiots!
Posted on Jul 19, 2008
Anonymous
SOURCE: cooktop wont unlock
Press and hold the "Top" button for five seconds. It worked.
Posted on Oct 27, 2008
Anonymous
SOURCE: oven door won't unlock
I had this same issue and consulted the owner's manual. Once on self clean it takes up to 3-4 hours for it to automatically unlock. It is a built in safety feature of the oven.
Posted on Feb 14, 2009
craig6773
craig6773
  • 116 Answers
SOURCE: After self- cleaning my Kenmore
This may be a silly question but, did you just try turning off the circuit breaker for a couple minutes to see if it resets itself when you flip it back on?
Posted on Nov 21, 2010
Kenmore elite oven door shows door locked how to unlock it
https://www.hunker.com/12438447/how-to-unlock-a-locked-oven-door-on-a-kenmore-range
How to Unlock Locked Oven Door on Kenmore Range Hunker
Quoting from the link shown:
Step 1 Read the display on the electronic oven controls, where the clock and timer normally appear. If the display reads "CLN" while the "Door Locked" light is on, the Kenmore range is in self-clean mode. When the Kenmore range is in self-clean mode, you must stop the cleaning process before the door will unlock.
Step 2 Stop the self-cleaning process by pressing and holding the "Stop/Clear" button for three seconds. The oven lock should disengage after three seconds. In some cases, a malfunction between the control panel and the locking mechanism prevents the door from unlocking.
Step 3 Hold the light switch for several seconds if the "Stop/Clear" button fails to unlock the range door. Engaging the light switch for several seconds resets the entire locking mechanism and overrides the "Stop/Clear" button.
Jun 15, 2018 | Kitchen Ranges
Oven door is locked out - Sears no help
      1. Step 1 Read the display on the electronic oven controls, where the clock and timer normally appear. If the display reads "CLN" while the "Door Locked" light is on, the Kenmore range is in self-clean mode. When the Kenmore range is in self-clean mode, you must stop the cleaning process before the door will unlock.
      2. Step 2 Stop the self-cleaning process by pressing and holding the "Stop/Clear" button for three seconds. The oven lock should disengage after three seconds. In some cases, a malfunction between the control panel and the locking mechanism prevents the door from unlocking.
      3. Step 3 Hold the light switch for several seconds if the "Stop/Clear" button fails to unlock the range door. Engaging the light switch for several seconds resets the entire locking mechanism and overrides the "Stop/Clear" button.
Jul 03, 2015 | Kenmore 30" Freestanding Electric Range...
Managemylife com
From the manual:
To turn the Cooktop Lockout Feature OFF:
1. Press and hold (_ until "CLO" appears (Figure 3). Continue holding
until a second beep sounds (after 3 seconds). I_1will disappear from
the display indicating the cooktop may be used normally (Figure 4).
Note: Starting a Self-Clean cycle will automatically turn ON the Cooktop
Lockout feature. The cooktop will remain locked until the Self-Clean cycle
has completed and the oven door has unlocked. If a power failure occurs
after the Cooktop Lockout has been activated, you must turn OFF the
Cooktop Lockout feature before being able to use the cooktop features
again.
Dec 14, 2013 | Stoves Kitchen Ranges
How do I fix an F40 code on a kenmore elite rlectric range model #790.46709603
The "F40" fault code indicates a Cooktop Lockout error. There is a "Lockout" control board that locks out the cooktop from operating whenever the "Clean" cycle is used. It's not normal to display "F40" unless there is a "Lockout" or an "EOC" (electronic oven control) failure. It may need one or the other or both boards replaced. If the cooktop will operate after the range has cooled and unlocked then it may need the EOC and not the Lockout board. If you can ignore the beeping and the F40 and the range will heat up again in the clean cycle and complete the clean cycle then it could have a faulty Lockout board. Here a link to a YouTube video with the instructions on how to access and replace the EOC.
Here is the lockout board if you need to order it.
Here is the EOC board if you should need it also.
All parts come with a 365 day, any part, any reason return policy.
Apr 06, 2013 | Kitchen Ranges
After self- cleaning my Kenmore Gas Range, I have not been able to get the 'Cooktop Lock' light turned off! So while I can use my oven for baking I can't turn the gas on the top of my stove! I have...
Nov 21, 2010 | Kenmore Kitchen Ranges
"Cooktop Locked"
Jul 19, 2008 | Kenmore 78823 Gas Kitchen Range
Oven door won't unlock
Jun 21, 2008 | Kenmore 46123 Stainless Steel Electric...
Need to unlock the controls of my Whirlpool gas oven
To Lock Or Unlock Cooktop
1. Turn all control knobs to OFF.
2. Press and hold the Cooktop Lockout icon keypad for 3 seconds. A single tone will
sound, and “Loc On” and a cooktop icon will appear on the display. After 3 sec-
onds the clock display will reappear.
3. Repeat steps 1 and 2 to unlock cooktop. “Loc OFF” will appear on the display for
3 seconds, and the cooktop icon will disappear from the display.
Feb 13, 2008 | Whirlpool SF367 Gas Kitchen Range
Kenmore 79012 / 79014 / 79019 Gas Kitchen Range Logo
171 people viewed this question
Top Kenmore Kitchen Ranges Experts
Marvin
Marvin
Paul Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
