I need to know how to change the pull starter rope on a 4620 poulan chainsaw
I have found that youtube is a great place for chainsaw repair videos.
Check this one and see if it helps. http://www.youtube.com/watch?v=PsJ0sygoVBQ
SOURCE: need to know which gas line to put the fuel filer
The one that goes directly to the carburetor. The other is most likely the primer bulb return. The filter hose needs to be long enough to reach all corners of the tank as saw is moved. HTH
Lou
SOURCE: i need to know how to replace the sprocket on
It is a Poulan PP4620(dependent on clutch adjuster - AV, AVHD, AVL or AVX)
Poulan.com/CurrentModels (Check in Illustrated Parts List (IPL) box)
http://www.poulanpro.com/node4043.aspx
Type just the model numbers (choose the suffix after the list is provided).
All 4 of these display an outboard clutch, use this as a removal guide:
R² Drive Link Outboard Clutch by Drivelink.blogspot.com
http://www.youtube.com/watch?v=cdqkIuVNUQc
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
SOURCE: how do you replace spring on a poulan chainsaw
A Poulan "P4018WT Gas Saw Type 1" IPL follows (may not be your saw):
http://www.ordertree.com/modelinfo/PWE/P4018WT-Gas-Saw-Type-1/75.P4018WT-Gas-Saw-Type-1.1.59.1.html
If yours is not a "Type 1" it can be found here:
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
The dash number of your serial number is the type.
If the spring is unwound:
Recoil Spring Rewind
I invert and secure the starter housing and rewind the spring large coil to small (need eye protection and both hands). I am right handed so I tension the spring enough to insert it inside the previous coil while holding what has already been installed with my left about 180° from my right hand. The tension will hold the spring in the housing once completely rewound. Then bend slightly the inner most part to engage the starter spool. The video explains how to tension the spring.
R² Starter Rope by SmallEng.com
http://www.youtube.com/watch?v=eRyy3MlsjVo
If you have more questions or need additional help please reply below and I will get back to you. Good Luck. HTH
Lou
Thank You for using FixYa.
A link to a Poulan "PP4620AV Gas Saw” follows (may not be your saw):
http://www.ordertree.com/modelinfo/PWE/PP4620AV-Gas-Saw/75.PP4620AV-Gas-Saw.1.59.1.html
If not your model number all IPLs can be found here:
The IPL (exploded parts list) for your saw is beneficial with disassembly/reassembly:
Poulan.com
The 4620 link has an outboard clutch remove it as demonstrated here (chain brake must be released else difficult to remove the clutch cover and impossible properly to reinstall):
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
SOURCE: I have a Poulan Pro 42CC 18' chainsaw and need to know how to lean out the carburator?
you dont neddle valve and carb kit
