SOURCE: Refrigerator warm, frost in freezer
take back panel off freezer and check for ice build up which will block air flow and temps will rise. melt off carefully with a hairdryer.make sure drain is also clear and use hot water and patience if blocked with ice. if fault re-occurs, you have a fault with defrost system
SOURCE: Frigidaire model # FRS26ZNHB2 side by side not cooling
T
From your description, you have a bad evaporator fan motor. The part number for a replacement motor is #5304445861.This is not a direct replacement but is more reliable.Remove everything in the freezer, take off the back panels and you will see the fan.
If there is a large frost buildup on the coils and the fan is turning you have a defrost problem. If that is the case, please call me at 334-347-0000 and I will walk you through it.
SOURCE: Fridge not cooling- top freezer frosting over
"Fan in freezer does not seem to be running"
This wiil cause it to frost up in the freezer and this fan is the only way to get cold air into the Fridge area.
SOURCE: Warm Fridge Section, Cool freezer section
Problem seems to be solved. I unplugged it for a short time and plugged it back in. I'm guessing it needed to be re-set.
SOURCE: maytag mff2557hew fridge not cooling. Freezer ok.
Sounds like the Freezer Fan is wearing out or is worn out. This fan problem is very hard to detect. The reason is that when the motor is starting to wear out the fan will spin, but at a much lower rpm. This is enough to keep the freezer cold. but will not ciculate enough air thru the freezer and the refrigerator to prevent freezer from and refrigerator from cooler. The cost to repair/replace this fan is a minimum of $300.00
Testimonial: "Your solution was right on the mark! The fan was spinning but not fast enough (according to my repair guy). Thanks again!"
