How do I set the fax to print a confirmation receipt confirming that the fax was sent or an error report that it failed?
SOURCE: fax confirmation
Some printers don't do that, some printers do.
Go to the preferences of your printer and set the confirmation there. Usually after sent a fax if no error message appears the fax has been transmitted.
SOURCE: Fax Transmission fail from Dell Laserjet 1815dn
what do we do if our dell fax machine lazer mfp 1825 doesnt send or recieve faxes?
SOURCE: No FAX status confirmation printed.
go into the fax settings (or setup) on the printer and make sure it is set to give a printed report after each fax reguardless of wether it goes through or not..
Testimonial: "Your response made me go into the menu and there I found an option to print the sending log. That works for me! Thanks for pointing me in the right direction."
If you need printed confirmation that your faxes were successfully sent, follow these instructions to enable fax confirmation before sending any faxes. Select either On Fax Send or Send & Receive.
The default fax confirmation setting is Off. This means that the HP All-in-One will not print a confirmation report for each fax sent or received. A confirmation message indicating whether a fax was successfully sent appears briefly on the display after each transaction.
To enable fax confirmation from the control panel
1. Press Setup.
2. Press 2, and then press 3.
This selects Print Report and then selects Fax Confirmation.
3. Press to select one of the following, and then press OK.
Off Does not print a fax confirmation report when you send and
receive faxes successfully. This is the default setting.
On Fax Send Prints a fax confirmation report for every fax you send.
Fax
On Fax Receive Prints a fax confirmation report for every fax you receive.
Send & Receive Prints a fax confirmation report for every fax you send and
receive.
