I have an older Olevia TV. There are stains around the outer edge of where the non wide- screen is. I am a smoker, are these nicotine stains that got inside the screen? Is there any remedy, can I clean inside the screen? SN VDLK 68250019
Contact any service technician. The set has to be disassembled to clean it; and it is a skilled work. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
SOURCE: Olevia 437-S11 stuck in standby mode
My classroom TV seems to be stuck in standby mode. Blue light is on but TV won't turn on either by push button or remote.
SOURCE: Olevia 437-s11 is stuck in stand by mode
It's not a firmware update, you do have a problem with the main board giving the power supply an ON command. Please have it looked at by a qualified technician.
SOURCE: I have sound but no picture on my Olevia tv, model 323-S11
this sounds like a mainboard issue , a replacement mainboard will solve this problem
SOURCE: I have an Olevia tv model 437-S11 that won't power up.
HI, i did what Mr Jeep says, i cant believe it but IT WORKS!!! Weeeeeee!!! XD, here are the steps:
1) I found (it was pretty hard) a firmware that works for the 437 S11 model, the 237 S11, you can use it with no problems, in the Folder you will encounter a PDF files, read it first, there mention all the steps
2) the other thing that you need is an USB A to USB B cable, this the USB cable that all Printers use, or you can go to an electronic store and ask for them. You have to Connect the USB Cable from the TV Service Port for Firmware Upgrade in the Back of the TV and then connect to your PC or Laptop
3)Here is the Link: http://dl.getdropbox.com/u/1022277/237-S11_061218A.zip
And remember to follow all the steps, doesn´t matter if the TV is OFF, just be sure the Power Plug is connected and the Power Led it´s ON.
Hope this work as works for me, See ya!!!
P.D. If you need some information, you can contact me at [email protected]
