Troy-Bilt Pony Garden Tiller Logo
A
Anonymous Posted on Oct 20, 2014
Troy bilt pony,moves so fastu cant hold it back,??????
When in gear too till it will outrun a motor cycle,cant hold it back?
Michele Sjoholm
Level 1:
New Friend:
Problem Solver:
  • Contributor 7 Answers
  • Posted on Oct 24, 2014
Michele Sjoholm
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
7
Questions
0
Helped
906
Points
6
I found that when you have the tiller at full throttle it can get away easily. Try pulling back the speed a bit and change the depth of the tines to grab a bit more but not enough to launch it. Good luck! Hope this helps you. Cheers, Michele
5 Related Answers
Anonymous
  • Posted on May 20, 2009
SOURCE: tilller will not run
Get the model # and serial # off of the sticker. Got to the Troy Bilt site and use the owners manual link. Need to leave off the last 3 numbers of the model #.
If that site does not have the manual, I've found them on the MTD site. I enter only the first 2 numbers of the model # and then hunt for my manual from the list.
If all else fails, you can call Troy Bilt at their # provided on the site.
Hope this helps.
Dwain Pippen
  • 377 Answers
  • Posted on May 25, 2009
SOURCE: troy bilt jr tiller
If you try to till too deep, this is what will happen. You have to start shallow and and gradually lower the depth on subsequent passes. That will even happen on my 'Horse' model if I try to go too deep too fast.
Anonymous
  • 173 Answers
  • Posted on Jul 08, 2009
SOURCE: my troy built pony drive belt broke. what do i
Take to auto parts store.
Kerry Degrand
  • 112 Answers
  • Posted on Jul 18, 2009
SOURCE: I have an older Troy-Bilt Pony Garden Tiller witha
From what I read you need a new rewind clutch and the spring and cord go into the housing. Briggs is easy to fix. contact me at [email protected] and I can send you what you need or you can send it to me and I will repair it very cheap!! Parts are available at almost any small engine parts place.
Anonymous
  • 843 Answers
  • Posted on Jun 15, 2010
SOURCE: broken pull cord on my manual start Troy-bilt Pony
It's definitely do-it-yourself in that no special tools or skills are required, but it can be a little tricky. You can see that the the recoil starter is in an assembly which is spot welded onto a metal cover. You have to remove the entire metal cover that includes the recoil starter. There may be 6 to 10 screws to remove to do that. When you get it off you will see a plastic spool that holds the cord. This spool is probably held in place by a couple of metal tabs that are bent down. Bend those tabs up with pliers. Underneath the spool is a spiral spring that provides the recoil. Take careful note of how this all goes together. Buy a new cord (available by the foot at a hardware store) and wrap it around the plastic spool. Use a piece of tape to hold the end of the new cord above the spool so you can thread it through the hole in the metal housing later. Put the spring and the spool in place, then wind the spool to put tension on the spring - about 5 turns in the direction that would push the string out through the hole. Once you have the spring "wound up" remove the tape and thread the end of the cord through the hole. Now bend those metal tabs back down. Put the handle on the cord end (or tie a knot) to keep the spring from pulling the end of the cord back through the hole. Reassemble the rest and you are in business.
Troy bilt pony 5hp rear tine tiller is leaking behind muffler on side of motor
Head bolts are probably loose, check the 3 nearest the mouffler and of course check all of them.
I have an old troy bilt pony rotertiller no serial tag
The decals r a good indication, they probably didn't have any more made than they needed. The only thing i can think of is, sometimes on the back side of the flywheel, (if u ever have it off) r some stamped numbers. One set of numbers is the month, and one set is the year it was made. Now that's the flywheel, but the engine should be the same year.
ballping
Troy Bilt Pony s/n P92695 5Hp Briggs. Drive wheels won't stay engaged. Lever jumps out. Can hold lever in with not much effort and will stay engaged. Any adjustments?
yes there is an adjustment. follow your shift lever down and you will find a block of iron with 2 bolts holding it. you will also see ond the lever itself a spring loaded pin.most of the time this pin gets gummed up and does not engage the block completely.clean and ensure the pin moves freely. if this does not solve the prob then the block can be moved up or down by loosening the bolts.
2answers
Can i see the models from 1983 to 1985,i need a belt so i can use reverse again but i dont now my model or size. my husband died 3 years ago. if i could see some pictures from the 1980's mine has a potatoe...
Your question doesn't give enough detail to properly answer. Do you know if the tiller is a Horse model or a Pony model? Troy Bilt made both models back in the timeframe you noted. The Horse model had tires that required air to inflate. The Pony model likely had hard rubber tires in that era. The Horse models had a reverse disc, no belt. The Pony had a belt.
Once you know which model you have - look for your closest Troy Bilt dealer and see if they can track down the part for you. They might appreciate it if you could provide the serial number - which is located on the pipe connecting the tiller transmission front half to the back half, where the tines are located. It's stamped right into the metal tube on both models.
3helpful
Troy bilt jr tiller
2helpful
2answers
Troy Bilt TB 465SS Pony 4 cycle weed trimmer won't start
Sounds like you need to take the carb. apart and clean it. I like to use a Den Tek Brush, (used for cleaning teeth), to clean the small ports in carb. they work great for this job. Make sure to either clean or replace the small screen in thcarb. as well.
Jim
2helpful
3answers
What type oil goes in the tranmission?
Trans oil! 90 or 140 wt.
I use 140 in my older tiller.
G
Top Troy-Bilt Garden Experts
Jay Finke
Jay Finke
kwfordguy
Level 1 Expert
Are you a Troy-Bilt Garden Expert? Answer questions, earn points and help others
