SOURCE: shower leak is it possible from Moen diverter to shower head
Check around the the front of shower and make sure there is no place that water can seep thru such as old calk and or loose tile and around fixture molding
SOURCE: shower head dripping cant turn shower knob off
Mixer valve needs repair. special tools required.
SOURCE: leaking shower head
Not unless you had a backward plumber , If the diverter at the faucet is open for tub, then no water will go up the shower, The shower may hold enough water up there to make it look like a drip, Even if the valve was leaking all the time, it would not go up, it would come out the faucet. It only works with pressure. Unless the valve was plumbed wrong,,, Hope this helps.
