Only the right high beam is working meter shows power all the way to the plug in at back of headlights both high and low on both sides
Unplug headlight and check resistance with a multimeter of each filaments across back of the globes.
This will confirm filament is ok if high resitance found then globe filament is blown. Or you could spend the money and try a new globe to eliminate possibility of globe failure .
Not Grounding.Clean The Grounds.Ground Block Around Your Battery..
