Hello, let do this. IR illuminator has a montary switch, that is when you push it comes on, and when you release it the IR goes off and it has a red LED to indicate the IR illuminator is being activated.
When you turn you binocular on there will be a green LED activated. This switch is DTSA---double throw sing activated. That is, one throw of the switch it turns on the binocular, the throw will turn off the binocular.
Also within the control panel there is timing circuit to keep the IR illumniator on for ten second the shuts off. Make sure you have the right switches etc. Let me know, then we can brain storm on this matter. stewbison
I think you will find that one 9 volt battery would not last any time at all. the 6 AAs have a big capacity and that's why they use them, a little 9v battery is intended for low power equipment.
I see it is supplied with a 12v AC adaptor, if you connect a 12V battery via the adaptor socket you may get a longer run time if its a rechargable battery even better.
I would strip the wires as carefully as I could and get them back together, get the 2 AA batteries back in there, and see what happens. Then go about making a permanent splice in the wires and getting the lens to stay on there, or ship it back to Russia for repairs. Or find somebody to do it. I'm sure it can be done. Hope this helps.
I'm pretty sure that your unit uses the 3V cr123 Lithium battery. You can get it at RadioShack. You can always take it down to radioshack and pretty quick you will find the correct batt.for the unit. Do not use rechargeable batts!
Define 'clear'. Is it blurry? Focus the scope or clean the lenses. Is it distorted? Don't know how to fix. Especially if the lens is cracked/scratched etc. Is it dark/snowy? Put fresh batteries in. Do you see black spots in the tube? Don't worry, certain amount of these are quite acceptable. Anyway: It's a night vision for pete's sake. The picture won't ever be like the one on normal binoculars.
Try to jank it left-right and simultaneously try to force it back to threads (either pulling or pushing). Don't hit it with anything since this may damage the insides.
How long have you had the system? Did you purchase from USNV or private party? If from USNV why not call them up and send it in for repair. If from private party,,,,,that's the chance you take. Sounds like you have either a failing power supply or an electrical short somewhere. In any event the system should be looked at by somebody who knows about night vision. If purchased within the past 2 years it will still be under warranty.
