I need to change the bulb in my oven but an't seem to get the cover off
SOURCE: kenmore oven: glass dome for interior light removal
Hopefully someone answered your question by now. If not, the glass bulb cover sticks sometimes, but it does turn counterclockwise. Be firm with it, let it know who's boss. Once you've removed it, you can replace the 40 watt appliance bulb. (The manual suggests you unplug the range or disconnect power for your safety). Good luck.
SOURCE: Can't figure out how to change the light bulb in the oven
normally the cover just unscrews but may be difficult if not removed for a long time - large pair of grips will help
SOURCE: how to change the oven light bulb in a candy f245
The glass cover does come off. Use some latex gloves or non skid material and grasp the lens firmly and turn counter clockwise.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Testimonial: "Spot on - I actually used insulating tape and water pump pliers- but I needed to know it would be ok."
SOURCE: unable to remove the glass cover to change the light bulb in oven
I went out and bought a 4 inch strap wrench from LOWE's. I had never heard of one before. After figuring out from the diagram how to use it, I wrapped it around the glass bulb cover and did a counterclockwise twist and off it came. P.S. I'm a girl so I feel pretty good about that project
